04 V6 - Mustang Evolution
Old 09-26-2014, 12:50 AM   #1
xrsfx's Avatar
04 V6
8.8 or 4.10 ?
xrsfx is offline   Reply With Quote
Old 09-26-2014, 04:29 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Exactly what are you asking?
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 09-26-2014, 08:19 AM   #3
xrsfx's Avatar
Mybad , should I just change my gears to 4.10 or should I just get a 8.8 gt rear end
Old 09-26-2014, 07:18 PM   #4
Really depends on the application. If you just want better acceleration and won't exceed bolt ons then 4.10's and a tlok will do. If you plan on forced induction or heavy engine work then I'd look for an 8.8 rear as it'll be stronger and have more gear ratio options.
Expect to pay 300-500 for a good shop to install gears/took so if you can pick up an 8.8 in good shape for less I'd jump on it. They can be had for fairly cheap if you look hard enough.
03:19 AM
