Whiney engine and power steering... - Mustang Evolution
Old 09-30-2014, 02:53 PM   #1
Mobley's Avatar
Hey guys I have a 2000 and the engine when idled sounds whiney, just annoys the crap out of me like I just have to just the shut the car off around people because its embarassing. Any ideas????
Also power steerong whine is horribly loud. Power steering fluid is good. Power steering hose is brand new, and when I bought car he said he changed the power steering pump twice and It didnt fix the problem. Any ideas on that?
Sent from my SGH-M819N using Mustang Evolution mobile app
Mobley is offline   Reply With Quote
Old 09-30-2014, 11:01 PM   #2
mazen123's Avatar
Rack and pinion might have a leak.
mazen123 is offline   Reply With Quote
Old 10-01-2014, 04:59 AM   #3
Bravebowhunter's Avatar
The whiney engine could be a pulley going out most likely the idler pulley and the power steering whine is likely because it needs a flush to flush the whole system and not just the pump and like the guy above me says could be the rack and pinion.
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 10-01-2014, 10:26 AM   #4
Mobley's Avatar
Thanks guys! Definrtly gonna check it out
Old 10-04-2014, 05:52 PM   #5
xfree143's Avatar
I have put on a new power steering pump and rack and pinion and it still whining noise. Not sure what else to do, I road in another guys 03 v6 and his didn't it also.
xfree143 is offline   Reply With Quote
Old 10-07-2014, 08:41 AM   #6
Sluder4's Avatar
Honestly every single v6 in our years does this. Mine has always done it and I'm not gunna spend 500 to fix it since that's not guaranteed to make it stop even once I've paid to install all new stuff and flush it.
Yeah the noise sucks but it's a problem we may have to live with. If someone figured out the exact thing that causes it I probably wouldn't spend much time and money on it. Instead just sped it on HP mods
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 10-07-2014, 10:22 AM   #7
Iryan7's Avatar
Not just a problem with mustangs, fords are notorious for their loud/whiny power steering. Just gotta learn to live with it.
Iryan7 is offline   Reply With Quote
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 06:31 PM
Radiator and power steering flush Xaperez100 Pre-2005 V6 Mustang 4 04-29-2013 06:41 PM
can u adjust ur electric power steering in 2011 like the 2012 and 13 manlaw38 2011-2014 V6 Mustang 1 03-23-2013 08:52 PM
Power steering delete and ac delete Speed_Mister 1996-2004 Mustang GT 26 03-22-2013 02:14 PM
How do I check to see if my alternator, AC condensor and power steering pump are working good? fitzsimons85 Classic Mustangs 3 08-20-2009 09:38 PM
05:30 AM
