Antifreeze leak - Mustang Evolution
Old 10-01-2014, 04:20 PM   #1
Iryan7's Avatar
Antifreeze leak
I am loosing antifreeze somewhere. I constantly see antifreeze on the tubes that lead out near the firewall on the passenger side. How hard of a fix is this?Click image for larger version
Name:	ImageUploadedByMustang Evolution1412202006.413237.jpg
Iryan7 is offline   Reply With Quote
Old 10-02-2014, 11:31 AM   #2
Bravebowhunter's Avatar
Where is the antifreeze? On the rusty pipe?
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 10-02-2014, 05:06 PM   #3
Iryan7's Avatar
No, these two tubesClick image for larger version
Name:	ImageUploadedByMustang Evolution1412291112.534138.jpg
But on a side note, where do the tubes that are rusty in the picture lead to? Should I replace them? Click image for larger version
Name:	ImageUploadedByMustang Evolution1412291149.793369.jpg
Old 10-02-2014, 05:10 PM   #4
Those two tubes are your heater they look pretty simple to replace might need to lift the car up though seeing that they go down. The rusty pipe leads to your accumulator which is part of your A/C it's normally for those to be wet all the time it's condensation from running your A/C they rust because the condensation gets under the paint and eventually peels it right off
Old 10-02-2014, 08:30 PM   #5
Iryan7's Avatar
Alright man, thanks. Appreciate it
Old 10-02-2014, 09:02 PM   #6
Iryan7's Avatar
Old 10-02-2014, 11:02 PM   #7
strips's Avatar
If its on the passenger side its the heater core. I know this because two weeks ago i have to change mine. I prey to god for your sake its not though because if it is then it will be the biggest pain in the *** to fix. Your ganna have to remove the dash. The entire dash. Its along job. If you do it yourself your looking at a couple of days of work. Since i am sure you've never replaced a heater core.And even if you have it will still take atleast 8-12 hours just because of all the stufff you have to take off and put back. If you go to a mechanic get ready to hear the money adding up. Also if you decide not to fix it might not be a problem now but for me it got worse. Soon smoke started coming out of my ac vents and i continued to smell anti freeze and then i couldnt drive a half amile without the car over heating. Things just got worse and worse
strips is offline   Reply With Quote
Antifreeze cross-line leak fish 1996-2004 Mustang GT 10 12-09-2011 06:52 PM
Antifreeze Leak -- Ford Says There ISN'T A Problem superstarjade 1996-2004 Mustang GT 13 02-28-2010 07:49 PM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
aw crap...antifreeze leak... mustangmare Pre-2005 V6 Mustang 2 11-13-2004 03:06 PM
Antifreeze smell? steedav6builder Pre-2005 V6 Mustang 6 07-15-2004 10:30 PM
» Members Mustangs
Roxie
OsirisGuy
Sexy
Alex117
Add your Mustang
08:24 PM
