possible IAC problem? HELP!? - Mustang Evolution
Old 12-10-2003, 12:59 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
My Fiancee has 00 mustang auto. It got cold and now it won't run. It'll start if you give it lots of gas but won't idle until it's warm, and then it idles at 5-700 RPM. I had this kind of problem with my mustang right after I got it and had it fixed under warrenty.
1. Does anyone have any other ideas or does this sound right?
2. if it does soudn like the air intake controler where is that to replace it.
2b. how much would one be?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
IAC 98StangGT 1996-2004 Mustang GT 0 09-12-2006 03:45 PM
IAC motor? Fast93Coupe 1979-1995 Mustang GT 3 06-25-2006 03:54 PM
Polished my IAC 97Stallion Pictures and Videos 5 01-08-2005 01:27 PM
IAC Valves 97Stallion Pre-2005 V6 Mustang 4 08-30-2004 11:35 AM
Where does the IAC go? Horse Pre-2005 V6 Mustang 4 01-23-2004 09:26 PM
04:16 PM
