My car is killing after start - Mustang Evolution
Old 10-06-2014, 06:33 PM   #1
cdardy23's Avatar
My 97 mustang is killing after I crank it up.. It's not the starter.. I think it's the fuel injectors.. Do anybody have some advice?!
cdardy23 is offline   Reply With Quote
Old 10-08-2014, 07:30 PM   #2
misterpancho95's Avatar
More advice would be needed to better answer your question ( I.e. what does it do when you turn the key to start, does it make any noise) if you can give more info I'm sure someone would be able to help you out more
Sent from my HTC0P3P7 using Mustang Evolution mobile app
misterpancho95 is offline   Reply With Quote
Old 10-19-2014, 11:12 AM   #3
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
If it starts and then dies could be a bad/week fuel pump. Run a fuel pressure test.
Jmustang78 is offline   Reply With Quote
Old 10-23-2014, 06:48 AM   #4
SpeedyG's Avatar
Could be the battery, gave it tested asap. Also can be the alternator have it tested.
SpeedyG is offline   Reply With Quote
Old 10-23-2014, 09:45 PM   #5
Jmustang78's Avatar
Region: Montana
Easiest way to check alternator is take pos terminal off while running. If stays running alternator is good
Is it normal for my hip to be killing me after driving my car? Its manual bluestorm52 2005-2010 Mustang GT 15 11-14-2011 08:46 AM
My tires are killing me. matthews.stang Mustang Wheels & Tires 13 12-17-2007 08:10 AM
Killing the Cats iceman08 Pre-2005 V6 Mustang 6 07-16-2006 12:39 PM
woot, now doing "killing" on 3.8 members.... jimmy_beaner The Bar 17 05-18-2005 08:13 PM
04:36 AM
