Question for the windstar guys... - Mustang Evolution
Old 10-08-2014, 02:29 PM   #1
Blue Angel's Avatar
How did yall make yalls CAI? Whats the best way to do it? Or what r some other ways to make it?
And did yall have to use spacers from the block to intake? Are thEy needed?
Would like to know so I can have everything ready to go when I finally install ot so it can be a quick install.
TIA
Sent from my SPH-L710 using Mustang Evolution mobile app
Blue Angel is offline   Reply With Quote
Old 10-08-2014, 02:49 PM   #2
Bravebowhunter's Avatar
I have a question too... What do you do with the egr? I'm in Canada and need to pass e-test I have an idea on making it functional but eliminated at the same time but don't know about the relocation of it with the Windstar intake do I need to fab up a mounting bracket for it?
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 10-08-2014, 03:48 PM   #3
Blue Angel's Avatar
U need to delete egr with this swap
Old 10-08-2014, 07:23 PM   #4
misterpancho95's Avatar
No that is not true you can get the egr from the Windstar itself well the egr mount because it is a low profile and you can use 3" PVC pipe with a 90° rubber pipe and a 45° that goes to the air filter but you'll have to get a 90mm lightning MAF just go to VAPauto.com they have two different install guides and a list of things needed also they do have a spacer that made out of g10 plastic but you can make one out of 2 pieces of1/8 inch steel its really not hard I did mine in a day
Sent from my HTC0P3P7 using Mustang Evolution mobile app
misterpancho95 is offline   Reply With Quote
Old 10-08-2014, 07:48 PM   #5
Blue Angel's Avatar
Vapauto.com dont got nothing for sale for the 99-00
Old 10-08-2014, 08:20 PM   #6
They did at one point mine is an 00 and some parts are interchangeable I got like 3 things from them (TB spacer, coil pack mount and IAC relocation bracket) but I had to fab the throttle cable and cruse control and yeah Steve from cap is not making any more things for the kit and seems to no longer be replying to emails. There are multiple threads that give really good info all will be different but take what you believe will help you but one thing I'll say be prepared for a lot of f bombs when you lose grip and scrape a knuckle.
Sent from my 831C using Mustang Evolution mobile app
Old 10-08-2014, 08:23 PM   #7
Blue Angel's Avatar
LMMFFAO! Thanks
Old 10-08-2014, 08:43 PM   #8
Yeah I was cursing my *** off but hell its worth it when you're done 10 HP and 7 TQ but if you have a good tune you can get more HP and TQ and if you make the CAI nice then you can gain a little more. Two things I really recommend if VAP still has them the TB spacer and you will thank god for it because without it you'll need to get a cowl hood or cut the hood and get a gt hoodscoop, second would be the IAC relocation bracket also the egr mount you can get off if the 96-98 Windstar for $7-11 bucks pick and pull junkyard. Also something no one ever tells you the the wires for the IAC you'll have to get 14 gauge the extend the wires. Hope I gave you a good amount of info
Old 10-08-2014, 09:01 PM   #9
Blue Angel's Avatar
Thank god I have a cowl hood already n I deleated my egr already n ima put the IAC where it gose on the intake but I did not know about the 14 gauge wire. That was a good heads up
Old 10-08-2014, 09:38 PM   #10
That's sweet I've been wanting to get a cowl good what size is yours? And yeah for the throttle cable I made a mount like this the only thing I had to do was make another part for it because I made it a little too long.
ID:	167639   Click image for larger version
Old 10-08-2014, 09:40 PM   #11
Also good luck on your build post pics when your done with it.
Old 10-08-2014, 09:59 PM   #12
Blue Angel's Avatar
But that's the thing I'm putting the AIC back on top to where you have your throttle bracket for the cables I'm also going to try and reuse my BBK 65 mil bottle body
Old 10-08-2014, 11:05 PM   #13
Well if you know anyone with a computer plasma cutter you can make a bracket like mine and just have them cut the holes for the IAC, buy an IAC gasket and sketch out how you want it made but leave the two holes and have the screw holes too lol and not sure if this will help either but this is how I mounted my coil pack on the Windstar
Old 10-09-2014, 02:03 PM   #14
superdrift's Avatar
Umm the intake fits with the stock hood
superdrift is offline   Reply With Quote
Old 10-09-2014, 02:08 PM   #15
It barely fit under my stock hood and it was still touching a little
Old 10-09-2014, 02:10 PM   #16
Blue Angel's Avatar
Good to kno cuz I have a 99 that if this one gose food with my 00 that I have a cowl hood on ima do it to my 99 too... do I have to take off the black cover on the hood for it to fit if I put the IAC on top of the intake where it suposto go?
Old 10-09-2014, 02:11 PM   #17
Blue Angel's Avatar
How did yall do the spacer from the tb to the intake? Cuz the bolts dont match up
Old 10-09-2014, 03:11 PM   #18
On which one the angled spacer or a mustang spacer and the liner doesn't have to come off but if you want more room its not a bad idea
Old 10-09-2014, 03:43 PM   #19
Blue Angel's Avatar
I tryed to line up my bbk 65 mm tb to the windstar n the windstar was a bit bigger n had a gap on top need a spacer to cover the gap n lighn up the holes for the tb. N also r spacers needed from the block to the windstar so u dont have to bent the fuel railsm
Old 10-09-2014, 03:54 PM   #20
Yeah if you don't want to bend the fuel rail yes and that's kinda strange are you using a gasket from the TB to the spacer and from the intake to the spacer I know stock tb works fine
Old 10-09-2014, 03:56 PM   #21
superdrift's Avatar
Name:	ImageUploadedByMustang Evolution1412891780.492660.jpg
Old 10-09-2014, 03:59 PM   #22
Blue Angel's Avatar
This one is aftermarket for a v6
Old 10-09-2014, 04:01 PM   #23
Blue Angel's Avatar
How did u get it so shiny?
Old 10-09-2014, 04:13 PM   #24
Damn id like to know too mine looks not as clean as that what kind of vacuum hoses did you use I need to update mine and I've seen some people with those but can't ever find them.
Old 10-09-2014, 05:59 PM   #25
superdrift's Avatar
I think it was painted along with some other engine parts before i got it.
Old 10-09-2014, 06:01 PM   #26
Blue Angel's Avatar
Think ima paint mine a black gloss
Old 10-09-2014, 06:02 PM   #27
superdrift's Avatar
I honestly couldnt tell ya they were installed at a local shop and picked out by the owner when i was getting the rest of the engine to show quality
Old 10-09-2014, 06:02 PM   #28
Blue Angel's Avatar
Can I use a degreeser to clean it?
Old 10-09-2014, 06:03 PM   #29
superdrift's Avatar
Yeah that would look great
Old 10-09-2014, 06:06 PM   #30
superdrift's Avatar
i dont use it but it should be okay
Old 10-09-2014, 06:11 PM   #31
Oh okay thanks I'll have to look for them more
Old 10-13-2014, 10:53 PM   #32
Blue Angel's Avatar
Where did u get ur elbow from? Is it pvc r rubber? I been looking for one but cant find nothing...
Old 10-14-2014, 04:24 AM   #33
superdrift's Avatar
Its probably pvc painted the same black as everything else in the engine
Old 10-14-2014, 08:19 AM   #34
Blue Angel's Avatar
What size?
Old 10-14-2014, 07:14 PM   #35
superdrift's Avatar
What size?
Lol idunno guess its time to get the tape measurer out
Another windstar question 94sccoupe Pre-2005 V6 Mustang 9 07-21-2012 01:54 PM
Windstar upper intake conversion Zebs5408 Pre-2005 V6 Mustang 14 04-11-2010 01:14 PM
windstar upper intake + stock hood? blackonblack Pre-2005 V6 Mustang 14 01-28-2010 07:39 PM
windstar intake jmp782 Pre-2005 V6 Mustang 5 01-12-2008 11:54 PM
Anyone have pics/info on the last Windstar SPI intakes? RGR The Bar 2 03-02-2006 01:02 PM
05:54 PM
