Trying to pin this down. - Mustang Evolution
Old 10-08-2014, 03:21 PM   #1
2004 V6.
Acceleration issues:
-Poor acceleration
-RPM drop while accelerating
-RPM drop when going from Park to Drive or to Reverse
-Hesitation
Spark plugs are recent, as in less than 3-4 months old. Spark plug wires were changed yesterday as two were damaged. Ignition coil was replaced at 145k.
My CAI's filter is sorta bent up since I didnt tighten it all the way after cleaning it once and it fell off near the house and I drove over it. Maybe that's affecting air flow or something.
I have cleaners for both the MAF and TB waiting for when I have time.. but is there anything else I should be looking at?
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 10-08-2014, 07:33 PM   #2
misterpancho95's Avatar
Have you checked the vacuum hoses, I know when I swapped upper intakes it would do the same and it was just a bad vacuum hose.
Sent from my HTC0P3P7 using Mustang Evolution mobile app
misterpancho95 is offline   Reply With Quote
Old 10-08-2014, 07:36 PM   #3
How many hoses are there and where? I know one connects to the air intake
-Cleaned TB, doesn't seem like there's any change. I did forget to mention I have an exhaust leak before the o2 sensors, so I'll have to investigate that. Apparently causes car to run lean and exhibit above symptoms
Old 10-09-2014, 04:22 PM   #4
Yeah sometimes, and there is one on the passenger behind the pcv that is connected to a plastic barb, and there's also the pcv's are you running breathers from the from the pcv holes on both sides or are you still using the vacuum hoses. I remember I was running breathers and one came out and my car just wanted to die and it would rev up and rev down
Sent from my 831C using Mustang Evolution mobile app
Old 10-10-2014, 08:58 AM   #5
I haven't added/done anything to the vacuum system so I'm assuming I'm using hoses.
The TB clean did fix that rpm drop from park to whatever, though. Later I'm going to clean the maf and see where it takes me. I have a laundry list of things to do, next is replacing my drivers exhaust manifold to address the leak.
Old 10-10-2014, 10:34 AM   #6
Well if that worked keep doing that good luck miri
Old 10-12-2014, 08:50 AM   #7
Thanks Pancho. I feel like the maf cleaning helped some. I'll just continue posting things as I get them done
Old 10-15-2014, 07:36 PM   #8
Bought exhaust manifold. Installing this weekend.
Car didn't react well at all to custom tunes; performance tune had the car with way worse hesitation (but under all that I could feel the performance increase)
Economy tune caused a grinding noise on acceleration which stopped once I went back to stock. Doing datalogs for tuners in the morning so they can see. He suspects it could be the CAI throwing the car off.
Could I be lean? I'm googling for how a car reacts to being lean and it's all "remove your spark plugs and see", i'm not trying to remove spark plugs right now, afraid of breaking a wire. Old plugs weren't white or anything though.
Old 10-17-2014, 09:28 AM   #9
IWstangboy03v6's Avatar
Clean your MAF of you haven't done so. My car was dropping idle so I cleaned the maf. It got a lot better and my check engine light went off
Sent from my XT1080 using Mustang Evolution mobile app
IWstangboy03v6 is offline   Reply With Quote
Old 10-17-2014, 03:02 PM   #10
I did clean MAF.
Changing exhaust manifold... it's unpleasant to say the least. Placing the new one is difficult.
Old 10-18-2014, 08:07 PM   #11
Dear diary,
when replacing exhaust manifolds loosen the other manifold at the midpipe to allow for clearance to place the new one. It's so nice not having the car go HEY HI EVERYONE TICK TICK TICK TICK every time I turn it on, but now at the midpipe on the passenger side it seems there's a teeny tiny leak, ill address it some other day. The car seems more lively. I bought Marvel Mystery Oil and I put some in when I got gas today, next week i'm changing the fuel and CAI filter... Past those two, there is compression test, and tranny fluid change.
Feel free to throw suggestions/ideas at me.
easy way to take of pin stripe? blackonblack Mustang Audio & Video 7 05-02-2010 10:07 AM
notched cross pin sonicpony03 Pre-2005 V6 Mustang 9 01-05-2009 07:00 PM
You could of heard a pin drop sonic04edge The Bar 8 08-20-2008 10:43 PM
07:15 AM
