Strong vibration coming from the back. HELP PLEASE! - Mustang Evolution
Old 10-10-2014, 10:20 AM   #1
vincemustangv6's Avatar
Unhappy Strong vibration coming from the back. HELP PLEASE!
Hey guys!
I have a stong vibration coming from the back under load, at low rpm and when climbing (between 1100RPM and 2000RPM)
I thought it was the u-joins so i changed them both (front and back), but still the same vibration.
I thought it was the driveshaft that was unbalanced, i took it out and took it to a transmission shop to balance it, it was unbalanced, (more than 0,5 that is the acceptable limit). Now its balanced but the problem still persists.
Would it be the harmonic balancer?
I checked the motor mounts, they were in perfect shape, same thing for the transmission mounts.
I checked and changed the oil of the driveshaft, no metal particles broke, everything seemed fine.
What could it be guys? i'm starting to loose faith on my 95 V6 mustang!
Thanks
Vince
vincemustangv6 is offline   Reply With Quote
Old 10-19-2014, 11:10 AM   #2
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
Have you checked the rear end gear tolerances or the races/bearings in the diff or the axles or pinion bearings?
Jmustang78 is offline   Reply With Quote
vibration coming from the back Sublime782 Pre-2005 V6 Mustang 4 07-11-2005 07:08 PM
the hate on the 6 was strong today Kyle The Bar 32 05-30-2005 03:47 AM
Remember when Iran said that any attack would be met with strong resistance? Brent The Bar 15 03-14-2005 01:59 PM
Are T45's strong? Js281GT The Bar 6 01-04-2005 11:49 AM
strong like bull tire The Bar 2 09-03-2003 01:33 PM
08:50 PM
