Transmission not going into 5th gear - Mustang Evolution
Old 10-11-2014, 08:23 AM   #1
I have a 96 Mustang with a T5 5 speed manual tranny. When I shift into 5th it is like shifting into neutral. It doesn't have a 5th gear. What can cause this and should I just replace the trans.
Jr Sager is offline   Reply With Quote
Old 10-19-2014, 11:05 AM   #2
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
If my memory serves me correctly the reverse gear and OD/5th gear are on the same shaft. Does the car go into and drive in reverse? If it does I think ur OD gear is probably bad. If not then the shaft or assembly for that gear set May be at fault. From the sounds of it ur sun rose are good as it allows u to put it in OD how ever u might check those too.
Jmustang78 is offline   Reply With Quote
5th gear, gear noise? SitinprettyGT 1996-2004 Mustang GT 6 01-10-2013 06:37 PM
Weird sound in 5th gear going around 60 Tylercribbs 1996-2004 Mustang GT 0 10-03-2012 09:05 PM
go into 5th damn you! gt274me 1979-1995 Mustang GT 14 06-08-2012 07:43 PM
Help! 1st gear issue / 5th gear grinding Missxalii General Mustang Discussion 2 06-06-2012 01:18 PM
4th to 5th shifting issue and hard as hell get into R - Black_Sunshine Pre-2005 V6 Mustang 7 03-18-2010 09:55 AM
06:18 AM
