Flashing Check Engine light, Random Misfire code - Mustang Evolution
Old 10-14-2014, 08:14 AM   #1
Hello, Recently i have had an issue with my check engine light being on constantly with a diagnostic code P0340 which was the camshaft position sensor code, But on top of that the car has been misfiring and if i accelerate to hard the light starts flashing and thats when i get the code P0300 random misfire doesn't tell which cylinder is misfiring. Things that have been done to the car recently (changed plugs and plug wires, fuel filter, and the camshaft sensor) which took care of the constant light it is no longer on. but i still get the flashing if i push the car to hard, it does not run rough all the time just while accelerating fast. the light flashes for 10 to 20 sec. and then it stops and the car runs fine. I am at my wits end with this car what else could it be? maybe a faulty Coil pack? bad plugs and wires even though they were just changed? the altenator has also been tested and is fine it was just replaced last year. I just dont want to keep dumping money on parts i don't need..Thanks in advance.
Crystalwilliams is offline   Reply With Quote
Old 10-14-2014, 08:58 AM   #2
In my case it was the coil pack.
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 10-14-2014, 09:04 AM   #3
Thanks! that was going to be my next step, is there any way to test them before i buy another?
Old 10-14-2014, 10:49 AM   #4
Bravebowhunter's Avatar
You can test them with an ohm meter but no need to it is 100% a coil pack that's what happens when they go.
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 10-14-2014, 11:57 AM   #5
If i wanted to check first , is it done on the car or do i have to take the coil pack off? maybe a pretty silly question..lol
Old 10-14-2014, 03:38 PM   #6
Can either way unplug it and test it by checking ohms on each circuit.
check engine
Flashing check engine light Seanp94 2011-2014 Mustang GT 29 10-12-2014 08:30 PM
Flashing check engine light after hard pull Pancakes 1996-2004 Mustang GT 2 08-28-2014 06:52 PM
2013 V6 Check Engine Light Flashing vcantrell 2011-2014 V6 Mustang 8 06-22-2013 09:43 PM
Check engine light flashing!!! rich671 Pre-2005 V6 Mustang 8 09-14-2012 05:39 PM
check engine light misfire code 98stang460 1996-2004 Mustang GT 6 07-27-2010 08:27 AM
09:49 AM
