Lowering - Mustang Evolution
Old 10-16-2014, 01:17 PM   #1
superdrift's Avatar
Lowering
I currently have the ebiach pro springs on my car and i wanna go lower by at least half an inch. What do you guys recomend?Click image for larger version
Name:	ImageUploadedByMustang Evolution1413486795.017025.jpg
ID:	167957Click image for larger version
Name:	ImageUploadedByMustang Evolution1413486835.415935.jpg
ID:	167958Click image for larger version
Name:	ImageUploadedByMustang Evolution1413486858.325783.jpg
ID:	167959Click image for larger version
Name:	ImageUploadedByMustang Evolution1413486887.152237.jpg
ID:	167960Click image for larger version
Name:	ImageUploadedByMustang Evolution1413486953.459001.jpg
superdrift is offline   Reply With Quote
Old 10-16-2014, 02:16 PM   #2
Laquisha's Avatar
I thinkk you will scrape speedbumps if u do. ahah
Old 10-16-2014, 03:14 PM   #3
superdrift's Avatar
Not if i go half an inch lower
Old 10-16-2014, 03:36 PM   #4
MattsMustang224's Avatar
Your mustang looks clean as hell!
MattsMustang224 is offline   Reply With Quote
Old 10-16-2014, 03:46 PM   #5
Laquisha's Avatar
half a inch and your already lowered? Just bag it lol. You'll be pretty damn close to be slammed.
Old 10-16-2014, 04:05 PM   #6
Or get coilovers
Old 10-16-2014, 04:11 PM   #7
superdrift's Avatar
Well im trying to cheaply lower it.
---------- Post added at 10:11 PM ---------- Previous post was at 10:11 PM ----------
Thanks man
Old 11-01-2014, 06:41 PM   #8
Good ride! Big brakes
Grandcrosser is offline   Reply With Quote
Old 11-01-2014, 08:00 PM   #9
superdrift's Avatar
Thanks
Old 11-01-2014, 08:40 PM   #10
Goose's Avatar
Will the sportline springs not work?
Goose is offline   Reply With Quote
Old 11-01-2014, 09:16 PM   #11
superdrift's Avatar
I have no idea. Are they lower than the pro's?
Old 11-02-2014, 05:45 AM   #12
Goose's Avatar
Smile
For later model mustangs yes they are about .5 lower than the pros.
Old 11-02-2014, 06:06 AM   #13
superdrift's Avatar
The rep from am said that the nextthing to do would be coilovers
Old 11-02-2014, 06:14 AM   #14
Goose's Avatar
Sure because coilovers are way more expensive than springs. I think the h&r super sports are even lower than the sportlines.
Old 11-02-2014, 07:52 AM   #15
mazen123's Avatar
You honestly have one of the nicest new edges Ive ever seen before dude, what a beaut
mazen123 is offline   Reply With Quote
Old 11-02-2014, 09:14 AM   #16
superdrift's Avatar
Thanks man.
---------- Post added at 04:14 PM ---------- Previous post was at 04:13 PM ----------
But arent coilovers adjustable?
Old 11-02-2014, 09:18 AM   #17
Goose's Avatar
Yes
Old 11-02-2014, 01:30 PM   #18
Bravebowhunter's Avatar
I love the colour of your stang!
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 11-02-2014, 01:53 PM   #19
superdrift's Avatar
Thanks
Old 11-09-2014, 02:55 PM   #20
dan96's Avatar
I scrape speed bumps and I'm still at stock height..
dan96 is offline   Reply With Quote
Old 11-09-2014, 04:39 PM   #21
superdrift's Avatar
If i get coilovers will the car be able to be higher than it is now?
Old 11-09-2014, 05:37 PM   #22
dan96's Avatar
If you get adjustable coilovers but they seize up easily. You're car won't handle the best also IMO
Old 11-09-2014, 06:16 PM   #23
superdrift's Avatar
As long as my car's handling doesnt completely change and make me have to go around corners 10mph slower than normal im good. Im wondering if i can have them at the exact same height im at now for daily use then when im going to a show i could lower it down to give it a better look?
Old 11-09-2014, 06:57 PM   #24
dan96's Avatar
Yes you just adjust the springs to whatever ride height you want. Make sure you keep the threads lubricated though because they start to seize and become harder to adjust.
Old 11-09-2014, 08:33 PM   #25
superdrift's Avatar
What is a thread? And What would i use to do that?
Old 11-10-2014, 01:56 AM   #26
dan96's Avatar
Name:   ImageUploadedByMustang Evolution1415609730.507593.jpg
the black is the thread and the orange ring is where you would adjust ride height
Old 11-10-2014, 08:00 AM   #27
superdrift's Avatar
Ahh okay so i would just lunricate the black part?
Old 11-13-2014, 10:28 AM   #28
xrsfx's Avatar
Your car already looks badass man
xrsfx is offline   Reply With Quote
Old 11-13-2014, 10:40 AM   #29
superdrift's Avatar
Thanks man but, it can always go lower
Old 11-13-2014, 10:56 AM   #30
I vote coilovers. I put Maximum Motorsports coilovers in my car and adjusting them is super easy. When there is zero load on the front wheels or the axles (jack stands under subframe connectors) the coils are only sitting on the bottom spring perch, not even touching the top, i can just go in there and twist it with my hand. Takes me longer to jack up the car than it does to adjust it..... BUT, when you adjust it you are going to need another alignment.
Old 11-13-2014, 10:58 AM   #31
Off topic.... Is that the Wilwood 12.88" 6 piston superlite brakes? Been thinking about getting them.
Old 11-13-2014, 04:16 PM   #32
superdrift's Avatar
Yes they are great brakes.
Old 11-16-2014, 05:52 PM   #33
IWstangboy03v6's Avatar
I'll buy your current springs from you if you end up switching them out
Sent from my XT1080 using Mustang Evolution mobile app
IWstangboy03v6 is offline   Reply With Quote
Old 11-16-2014, 05:54 PM   #34
Laquisha's Avatar
Old 11-16-2014, 06:00 PM   #35
Steeda X2 ball joints.
Lowering my car? white99 Pre-2005 V6 Mustang 7 03-16-2004 10:20 AM
Hey guys that are good at lowering, need help for poster DUW Zim The Bar 2 10-13-2003 09:54 PM
Bushings for lowering springs Blue232 Pre-2005 V6 Mustang 10 10-09-2003 12:33 PM
Where can i get lowering springs (01' Vert) Stang01 Pre-2005 V6 Mustang 3 09-30-2003 10:44 AM
Lowering Springs -- How Much? Stang01 Pre-2005 V6 Mustang 7 09-20-2003 12:07 PM
04:47 AM
