Where does the IAC go? - Mustang Evolution
Old 12-10-2003, 03:25 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I'm almost sure I need to replace the IAC on my fiancee's car. it's acting just like mine was before I had mine replaced. This is something I'm going to have to install since we don't have the money to take it to a shop. I'm pretty handy, but I don't even know where this thing goes. Is it in the intake tube or where?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 12-10-2003, 09:07 PM   #2
Rick0636's Avatar
The IAC is attached to your throttle body.
Old 12-10-2003, 09:11 PM   #3
Rick0636's Avatar
If you have a Haynes manual look in section 4-11, this shows the procedure to remove, clean and or replace it.
Old 12-11-2003, 06:57 AM   #4
Region: Iowa
Sweet, you rule.
4-11 ok, I didn't even think to look in that manual. What it covers is kinda patchy sometimes.
I really apreciate the help.
once again. You rock
Old 01-23-2004, 09:26 PM   #5
Ponycarman's Avatar
Clean it first, I had an IAC error code, cleaned it and it's fine.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
IAC 98StangGT 1996-2004 Mustang GT 0 09-12-2006 03:45 PM
IAC motor? Fast93Coupe 1979-1995 Mustang GT 3 06-25-2006 03:54 PM
Polished my IAC 97Stallion Pictures and Videos 5 01-08-2005 01:27 PM
IAC Valves 97Stallion Pre-2005 V6 Mustang 4 08-30-2004 11:35 AM
possible IAC problem? HELP!? Horse Pre-2005 V6 Mustang 0 12-10-2003 12:59 PM
09:14 PM
