Lowering - Mustang Evolution
Old 10-20-2014, 09:20 PM   #1
Dillon_fitz16's Avatar
Lowering
I have a 97 stang and want to lower it some, would I have to get that done at a shop or would there be any way for me to do that myself and possibly save a bit of money?
Dillon_fitz16 is offline   Reply With Quote
Old 10-21-2014, 09:41 AM   #2
RaceRed13's Avatar
If your only thinking about springs yes, you can do it at home with the correct spring compressor and knowledge. Its better for a shop to do it. I would never do it myself.
Im lowering my stang in about 3 weeks and im taking it to a shop.
2013 v6 Race Red, GT front grill with Boss 302 MMD foglight covers, double layer tint, Mickey Thompson 285/35-19 19x10 rear, 255/40-19 19x8.5 front, Silver AMR wheels, H&R Super Sport Springs with camber bolts, LED interior/ license plate, MMD Eleanor louvers.
RaceRed13 is offline   Reply With Quote
Old 10-22-2014, 05:36 AM   #3
Bravebowhunter's Avatar
Lowering a stang is easy I did my buddy's in his drive way with no spring compressor or any special tools in an afternoon. Lift the car by the body and you can pull the springs out by hand. Just be careful they still have a little bit of tension on them. You might have to pull the brakes off the front to be able to do it
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 10-22-2014, 09:19 PM   #4
Did you put smaller springs in it or what?
Old 10-23-2014, 02:52 AM   #5
kickerofdoom's Avatar
I did my own and put in ford racing c spring
Old 10-23-2014, 03:23 AM   #6
kingstrider's Avatar
Different model but I did mine last month with the FRPP handling pack. New shocks, struts, lowering springs, sway bars etc. Did it on jack stands over a weekend, there are some pics of the install in my garage.
Doing it yourself will save a lot of money, might be worthwhile to replace the shocks and struts with better ones while you are in there. Don't be stupid, rent a spring compressor for the front end. Just do your research before you buy parts or start turning wrenches.
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 10-23-2014, 05:16 AM   #7
Yes we lowered it.
Old 10-23-2014, 03:46 PM   #8
RaceRed13's Avatar
Yes we lowered it.
Awesome man how long did it take?
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 10-23-2014, 04:59 PM   #9
One afternoon the springs aren't bolted to anything when you lift by the body there just sitting there and you can just pull them out might have to pry a bit so be careful. All I'm sayin is it can be done without a spring compressor just BE CAREFUL!!!
Lowering my car? white99 Pre-2005 V6 Mustang 7 03-16-2004 10:20 AM
Hey guys that are good at lowering, need help for poster DUW Zim The Bar 2 10-13-2003 09:54 PM
Bushings for lowering springs Blue232 Pre-2005 V6 Mustang 10 10-09-2003 12:33 PM
Where can i get lowering springs (01' Vert) Stang01 Pre-2005 V6 Mustang 3 09-30-2003 10:44 AM
Lowering Springs -- How Much? Stang01 Pre-2005 V6 Mustang 7 09-20-2003 12:07 PM
04:30 AM
