Wheel Fitment?? - Mustang Evolution
Old 10-30-2014, 01:55 PM   #1
Wheel Fitment??
Hello Everyone!
New to the forum...
I have a '99 3.8L and I am curious about wheel fitment from newer generations.
Am I going to find any issues??
Thanks!
Jeff
'99 Mustang 3.8L
Red
Mods: Magnaflow Exhaust
jeffedmondson is offline   Reply With Quote
Old 10-30-2014, 07:01 PM   #2
Mile high JDF's Avatar
They will fit but the offset is different so you're gonna need to run spacers
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 10-30-2014, 07:03 PM   #3
Any suggestions on spacers?
Back in the day I used a set and my old 300 shook like mad.
'99 Mustang 3.8L
Red
Old 10-30-2014, 07:46 PM   #4
Wheel Fitment??
Aftermarket wheels will fit. If you happen to have a big front brake kit, like Brembo or Wilwood, they require 17-inch or larger wheel with certain spoke shape and wheel offset. For SN95 mustang, a 9-inch-wide rim with a 6-inch backspace works well.
If you get a 9-inch-wide wheel with zero-inch offset, it means that the location of the wheel mounting surface is going to have 4.5 inches of rim width on each side of the wheel mounting surface. If you have positive offset, it would move the rim closer to the centerline of the chassis. The distance between the wheel mounting surface and the back side of the rim, in inches, is called backspacing. Therefore, a recommended 9-inch rim with 6-inch backspace is the same as 9-inch rim with a 1.5 inch of positive offset.
For your year of mustang, 1999 v6, you have your OEM wheel 15 x 7 with 5 inch of backspacing, or 1.5 inches of positive offset, if I did the math right.
Hope it makes sense. Whether you need spacers or not, you can decide for yourself. Once you have chosen the right wheel, you might want to ask people around what tires work great in combination with it.
Hope it helps.
Grandcrosser is offline   Reply With Quote
Old 10-30-2014, 07:59 PM   #5
Some people also do a speedometer calibration after they change wheel size.
Old 10-30-2014, 08:02 PM   #6
Thanks guys!
Huge help!
'99 Mustang 3.8L
Red
Wheel and Tire fitment rayrivas Mustang Wheels & Tires 5 11-07-2013 12:49 PM
Wheel fitment 2010-2013 ARfirefighter Mustang Wheels & Tires 8 11-21-2012 09:32 PM
wheel fitment. robert3188 1979-1995 Mustang GT 9 12-03-2011 09:25 PM
17x10.5 wheel fitment question Evil J Mustang Wheels & Tires 4 10-30-2009 07:19 AM
69 tire and wheel fitment Indymustang Classic Mustangs 1 09-12-2006 08:25 AM
05:22 PM
