What to expect from these modifacations? - Mustang Evolution
Old 11-02-2014, 09:20 PM   #1
I have a 1999 mustang manual v6, I have searched around for the mods that best suit my plans (staying around factory mpg, but adding power output). As a goal I would like to give the same year stock v8 a run for its money, what do you expect as 1/4 mile time (stock is 15.9ish)? No specified companies due to indecision of what I want. Thank you in advance. And here is the list:
Dual glasspack cat-back
Cold air intake (possible windstar switch)
Under-drive pulley
Subframe connectors
8.8 end, 3.73 gears
Traction lock 8.8
Throttle-body
Coil pack
Tuner
Maybe's:
Aluminum driveshaft/flywheel
Turbo (if I save up enough)
4.3 liter conversion (if I save)
SimpleSixer is offline   Reply With Quote
Old 11-02-2014, 09:32 PM   #2
Add mac long tube headers with h-pipe to your wish list and you will have a decent running car. If you want to run with the 4.6 or outrun it you need to go with your maybe list.
Bigshow14 is offline   Reply With Quote
Old 11-07-2014, 10:29 PM   #3
LaserRed99's Avatar
Yep, cheapest way by far to hang with/beat the GT is forced induction.
Or, I know you probably hear this a lot but I gotta be honest, why not take the money you were going to spend on mods, sell the car and buy a GT version? Then any mods you do later will give you so much more.
'03 Mach 1 5spd
Fully forged Manley rods/pistons, Cobra crank, ARP hardware, 8.5:1, Procharger P1SC w/ intercooler, AFM power pipe, 60# injectors, 03/04 Cobra tank with dual fuel pumps, Kenne Bell Boost-a-Pump, O/R X pipe and Flowmasters, Exedy stage 3 clutch, Steeda Tri-Ax, Front and rear upper + lower control arms, Ford Racing springs, Bob Monks tune 448 rwhp @ 9 PSI
LaserRed99 is offline   Reply With Quote
Old 11-08-2014, 05:52 PM   #4
superdrift's Avatar
You would basically have a different car.
superdrift is offline   Reply With Quote
What to expect from these modifications SimpleSixer New Member Introductions & Greetings 2 11-02-2014 08:55 PM
SO you expect to start your car up... PureVenom Pictures and Videos 17 01-31-2007 02:31 PM
what should I expect to pay for a decent.. MonteCitan Mustang Audio & Video 9 09-04-2006 12:23 PM
what to expect? a00v6stang Pre-2005 V6 Mustang 6 02-15-2006 12:18 PM
06:54 PM
