No Heat And Over Heating - Mustang Evolution
Old 11-03-2014, 07:14 AM   #1
SLiM2775's Avatar
Ok, Hopefully someone can help. I put in stuff for a head gasket leak and now I have no heat and it is overheating. The stuff I put in said to add to the rad when the car was cold, then run at idle for 15 min with the heater on full and on the floor setting. But I forgot to turn the heat on. So any advice on what it could be, I'm hoping its just the thermostat, I bought one so that is the first thing I am going to replace, then the water pump if the thermostat doesnt fix it. I'm hoping I didnt clog up the heater core. Is there anyway to check if it is the thermostat? Any advice would be great.
SR CAI
JVC Head Unit, 1000 Watt Pioneer Amp, Two 10" Pioneer Subs.
SLiM2775 is offline   Reply With Quote
Old 11-09-2014, 06:00 PM   #2
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
Put thermostat in hot water see if it opens. Also u should be able to pull the heater core hoses on the fire wall to see if coolant is getting to it
Jmustang78 is offline   Reply With Quote
Old 11-14-2014, 08:53 PM   #3
davidcseifert's Avatar
Region: Arkansas
Turning the heat on affects nothing about how that stuff works, most likely clogged the rad and heater core making you lose heating and the car itself overheating. Any type of stop leak stuff like that has a good risk of messing up something.
blower/new cam soon
Over heating and antifreeze? Evangreco118 2005-2010 V6 Mustang 6 08-12-2014 12:14 PM
over heating and power loss wootman101 Pre-2005 V6 Mustang 0 12-12-2013 11:24 PM
Over heating Contourdrew 1979-1995 Mustang GT 1 12-23-2011 02:39 AM
Over heating Joshfelder 2005-2010 Mustang GT 5 06-04-2011 11:10 AM
Please Help...I'm going in circles. New engine, over heating and missfiring. rob4292 1996-2004 Mustang GT 4 05-31-2007 02:15 PM
05:19 PM
