Wierd Noise - Mustang Evolution
Old 12-10-2003, 11:18 PM   #1
Wierd Noise
i have a wierd noise coming (i think) the rear of the motor. its kinda like a thumping with a sqeek every once and a while. its a 2003 5 speed with 16000 mile. got any suggestions???? i might have to take it to ford and have warrenty work done. that means ill have to take off headrs, exhaust etc. im kinda bumed i hope its like the h pipe shaking.
badazzstang is offline   Reply With Quote
Old 12-10-2003, 11:59 PM   #2
Rick0636's Avatar
Changing exhaust systems shouldn't effect your warranty, it will only void the warranty on the exhaust system, which you have taken off and aren't using anyhow. The aftermarket stuff you have added wouldn't be covered by Ford naturally. If you had the exhaust system put on at a muffler shop go there and have them check things out and see if any of that could cause your noise. If not you shouldn't have to remove it to go to Ford. Just my thoughts.
Old 12-11-2003, 01:01 PM   #3
i did the whole exhaust myself. i got 4 lifts so taking it off this weekend would be no problem. but now its doing something else.
now when idoling it loping real bad. like it has a cam and it wants to die out. got any suggestions??? i was thinking bad gas? i changed the plugs. helped a little.
now there is no whine/ sqeek or knock
Old 12-11-2003, 01:27 PM   #4
checked the h pipe i didnt seem to be loose?!?!
wierd clank v6stang04 Pre-2005 V6 Mustang 2 10-10-2009 11:28 AM
wierd noise ??? yoshiStang19 Pre-2005 V6 Mustang 20 08-05-2009 03:36 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
Wierd Noise SeadudeRXP Pre-2005 V6 Mustang 6 02-13-2006 02:55 PM
wierd noise InVaDeR Pre-2005 V6 Mustang 16 09-21-2004 05:31 PM
08:28 PM
