New gears - Mustang Evolution
Old 11-09-2014, 11:09 PM   #1
xrsfx's Avatar
New gears
When I put 4.10's on my v6 I'm going to need s speed calibrator ? Or can I just by the gt gauges ? I heard that if I get new gauges then I won't need to buy the speed calibrator tool from am
xrsfx is offline   Reply With Quote
Old 11-09-2014, 11:25 PM   #2
You need to calibrate the speedometer. GT gauges won't do anything.
GTs never came with 4.10s, so those would also need a calibration, no way around it. You can either use a calibration tool like mentioned, or you can get a custom programmer for it and tune it at the same time.
Old 11-09-2014, 11:27 PM   #3
xrsfx's Avatar
What's cheaper
Old 11-09-2014, 11:29 PM   #4
xrsfx's Avatar
What do you mean a custom programmed ? I have a bama tuner ready to use. But with the gears I would be going faster than 120 wouldn't i? So how is the speedometer going to keep up
Old 11-09-2014, 11:34 PM   #5
Let me break it down..........
When you do the gears your speedometer will be off, so if you are going 65mph it will read 80 (as it was in my case with 4.10s). So you need to correct that, you can do that with the programmer or the sct tuner.
When it comes to actual mph.... You are aware that when you install those gears every single one of your gears shortens also right? Its not just throw them in and be fast all of a sudden. In my personal car with 4.10s my 4th gear (5 speed manual) redlines at 110mph, so anything after that i am in overdrive, which is useless. My speedometer goes all the way up to 150, but i won't get there unless i change out the gears again or i do head work and up my redline to 7k. Hell even with stock gearing my car has a hard enough time getting to 130mph.
So how fast you will be going will depend on a lot of factors. Yea, it will be easier to get up to that higher speed with the 4.10s than stock gears, but you have to take in other variable into account.
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
08:05 PM
