99 v6 won't turn over - Mustang Evolution
Old 11-20-2014, 08:02 AM   #1
Sluder4's Avatar
So my car won't start for the first time since I bought it in 2008. I put a new battery in it last summer and it tries to turn over so I know it isn't the battery. It sounds like it always does when I go to start it and the battery doesn't sound weak.
So it must be the starter or the solenoid then correct? How do I tell which one it is? I can change them both myself I just need to know which one is bad.
It tries to crank just fine it just won't turn over.
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 11-20-2014, 08:45 AM   #2
samuelsmith's Avatar
The solenoid is in our starter in the 99-04 Mustangs. Should be a easy fix other than getting out the top starter bolt.
Old 11-20-2014, 09:07 AM   #3
Sluder4's Avatar
Well hopefully it's the starter and nothing worse. I looked up how to get the old one out and everybody did say the top
Bolt sucks lol. I'm gunna try and jump it off but I know the battery isn't dead so jumping it of is just to put my mind at ease lol
Old 11-21-2014, 09:36 AM   #4
You need several extensions and a elbow. Look underneath the motor mount ,look at the starter, and you will see the bolt. You will need to put the extensions below the motor mount. The bolt will come off with a little patients.
Need help quick, won't turn over properly. 85Muscles 1979-1995 Mustang GT 9 04-09-2014 10:29 AM
2004 Mustang 3.9L won't turn over tdaniel04 Pre-2005 V6 Mustang 44 12-22-2013 10:32 PM
How to Mute Kenwood Nav Voice Prompts / Turn-by-turn Guidance EastTNMustang Mustang Audio & Video 0 11-03-2013 04:25 PM
1995 GT Cam won't turn TheLast5.0 1979-1995 Mustang GT 10 08-29-2012 01:23 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
12:37 PM
