1995 mustang with supercoupe swap - Mustang Evolution
Old 11-25-2014, 08:00 PM   #1
Hi I need help with my mustang it was originally a v6 but the guy I bought it off had done the supercoupe swap so the 3.8 supercharged so when I got it it ran fine now when it's cold it won't run I have to hold the gas to keep it running and when it's hot it revs around 2 grand until I let out the clutch a little in gear then back off and it runs fine for a bit. I'm stumped any ideas ? Thanks
matt1993 is offline   Reply With Quote
Old 11-27-2014, 02:37 PM   #2
Bravebowhunter's Avatar
What's it sound like when you rev it? Does it sound like it's skipping a beat or anything?
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 11-27-2014, 05:56 PM   #3
A little bit but not really
Old 12-07-2014, 05:06 PM   #4
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
We just had the same problem with a dodge we have at the shop. Ended up being a sensor! Crank I think could b wrong? But it was a sensor
Jmustang78 is offline   Reply With Quote
1995 mustang
1995 Mustang Cobra :: 1995 Ford Mustang Cobra jwhayne0001 Member Garages 0 08-20-2011 11:22 PM
1995 Mustang GT :: 1995 Ford Mustang Ripastanky Member Garages 0 06-15-2011 12:01 PM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
Check out my new site Mustang Supercoupe trevradman Pre-2005 V6 Mustang 2 04-02-2006 05:01 AM
*DUW* Adaption of supercoupe m90 twinscrew to splitport tire Pre-2005 V6 Mustang 5 09-22-2003 06:59 PM
01:04 AM
