Supercharger - Mustang Evolution
Old 11-25-2014, 08:58 PM   #1
superdrift's Avatar
Supercharger
I have an automatic transmission so nothing too crazy on power but im looking for a cheep supercharger that would add 50-70hp and still be reliable
superdrift is offline   Reply With Quote
Old 11-25-2014, 09:18 PM   #2
Rapinator126's Avatar
Seriously
Old 11-25-2014, 09:26 PM   #3
Cheap
Reliable
Fast
You can only pick 2
Old 11-26-2014, 07:54 AM   #4
Bravebowhunter's Avatar
If your looking 50-70 hp just change your valve train to a roller valve train. Cheaper then a supercharger and doesn't affect your reliblility.
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 11-26-2014, 07:59 AM   #5
superdrift's Avatar
I have no idea what that is
---------- Post added at 02:59 PM ---------- Previous post was at 02:58 PM ----------
Originally Posted by Rapinator126 View Post
Seriously
Yeah?
Old 11-26-2014, 08:26 AM   #6
No hate but this is why I will swap a V8 5.0 in this car
What the hell is the point of spending 4500-5000 on these V6s that wont even get you to 300 rwhp with this crappy 3.8 engine? Thats why I will be going with a 5.0. That motor responds so much better to power and there are way more aftermarketsupport than the 3.8
A donorcar r
fordmustang3.8 is offline   Reply With Quote
Old 11-26-2014, 08:32 AM   #7
superdrift's Avatar
A donorcar r
Keyword cheep. Like a used supercharger or something that would make the car a tad bit more respectable
Old 11-26-2014, 10:04 AM   #8
superdrift's Avatar
If it costs more than $2000 ima just drop a 3v gt motor in it
Old 11-26-2014, 10:46 AM   #9
Yeah?
You replace your lifters with roller lifters and you replace your rockers with roller rockers. And you can even get bigger roller rockers to give you more valve lift better air flow and a lot less friction so the motor can turn easier sending more power to the wheels.
Old 11-26-2014, 01:56 PM   #10
cozny's Avatar
A donorcar r
Wich 5.0? The 94-98 5.0 motors are just as sad. I would just save up for an new edge gt.
cozny is offline   Reply With Quote
Old 11-26-2014, 05:27 PM   #11
Actually only 94-95 SN95 were 5.0's, 96+ were 4.6
Why were they sad motors? The aftermarket they support is amazing thus it is WAY cheaper to get that quick than the crappy 3.8
Old 11-26-2014, 05:31 PM   #12
cozny's Avatar
94.95*
Old 11-26-2014, 05:43 PM   #13
cozny's Avatar
There both bad motors, there outdated and since its an old motor there not reliable compared to a newer motor. The 5.0 can be made to go fast(they both can be) but in the end of it all, it's not practical. Also insurance is going to eat you alive. And are you aware of everything you need to change? (It's not as simple as just removing the old motor and putting a new one in.)
Old 11-28-2014, 04:55 AM   #14
The transmission from the 94-95 5.0 and 99+ is compatible. You can just bolt on
And I know..you have to change the wiring harnesses, ecu, etc. Guess what? Still easier than swapping a 4.6 in because 4.6 is far different than the 3.8. The 3.8 is similar towards the 5.0. Also I don't know about you but the 5.0 responds to mods and power far better than the 3.8 single or split port
For $5000 you can swap in a 5.0 and supercharge the car and already have numbers exceeding the 3.8 limits as much as going to 320-350 rwph + the bolt ons you do
With the 3.8? For $5000 (procharger) you STILL don't reach 300 rwhp even with a tune, and you still get stomped by Mach 1's or even 99-'01 Cobra's.
Old 12-01-2014, 10:57 AM   #15
There is so much bad info recycling and fail in this thread my eyes and brain are how hurting. .. I do want to give the benefit of the doubt and write the one about the roller rockers off as a bad joke.
Old 12-07-2014, 04:10 PM   #16
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
Supercharger
Get the 4.2 bottom end and the SC Tbird top end and u will have a decent set up! U can push way more than 300 out of the 3.8!!! That set up won't break the bank either if u know how to do it yourself!
Jmustang78 is offline   Reply With Quote
Old 12-07-2014, 06:15 PM   #17
superdrift's Avatar
So where can i get that bottom?
Old 12-07-2014, 06:25 PM   #18
94.95*
Missed this.
The 94/95 Cobras have a great motor, its like a 99-04 PI motor but with a pair of balls down low. They were underrated too usually making around 235 to the wheels bone *** stock and take to mods REAL well. Also stupid easy to work on.
Also for the regular GT... you can do GT40 heads cleaned up for $400 or so if you are good and then $150 for a GT40 intake. Swap the heads/intake in an afternoon and leave the stock cam and don't even have to tune and the car will pick up 40whp.
Old 12-07-2014, 07:02 PM   #19
Jmustang78's Avatar
Region: Montana
Supercharger
Any 4.2L ford van or F150. And make sure the top end comes from a 94-95 Tbird! They had better top end and bigger injectors than their predisessors
Old 12-07-2014, 07:36 PM   #20
superdrift's Avatar
So any tbird?
Old 12-07-2014, 10:57 PM   #21
Jmustang78's Avatar
Region: Montana
So any tbird?
No the 94-95 SC Tbird
supercharger/headers smokin6 Pre-2005 V6 Mustang 1 10-28-2003 05:35 AM
Next Gen Electric Supercharger??? Rellik Pre-2005 V6 Mustang 31 10-13-2003 07:03 AM
supercharger el cheapo Pre-2005 V6 Mustang 0 08-20-2003 10:34 PM
$200+ complete supercharger, help Stang01 Pre-2005 V6 Mustang 3 07-20-2003 04:07 PM
Supercharger or Nitrous? ERICK Pre-2005 V6 Mustang 8 05-12-2003 02:41 PM
09:12 PM
