Binding when turning in reverse - Mustang Evolution
Old 12-03-2014, 10:45 PM   #1
2000v6stang's Avatar
Region: Iowa
Awhile back I noticed that when I am backing up like out of a driveway and I turn the wheel there is a clucking sound and you can definitely feel that it is binding. It seems to be getting worse, I mean when it first started I needed to turn the wheel all the way to get the binding to happen now it seems like I don't have to turn it so far. Any ideas on what it could be? Could it just be a alignment problem because I do need one but its parked for the winter so wont get one till spring. So if its something else I would like to fix it when its sitting over winter.
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is offline   Reply With Quote
Old 12-07-2014, 05:59 PM   #2
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
I've seen this problem in other vehicles weird that it is in just revers. But have u had the power steering flushed or checked ur rack?
Jmustang78 is offline   Reply With Quote
Old 04-01-2015, 09:56 PM   #3
which side does it sound like its coming from and which way are you turning when you hear the suspect noise
99whitev6 is offline   Reply With Quote
Old 04-01-2015, 10:05 PM   #4
Jmustang78's Avatar
Region: Montana
So update mine started binding a little too but in reverse and pulling into parking spots... Found out the next day that my ball joints were bad when the A arms hit the ground! Replaced them and all is well now no binding squeeking or anything
Old 04-01-2015, 10:08 PM   #5
this is actually where i was getting at..same thing happened to me and several customers vehicles
Old 04-01-2015, 10:09 PM   #6
except my c arms did not fall....did not get that bad..lol
Old 04-01-2015, 10:15 PM   #7
Jmustang78's Avatar
Region: Montana
YA I was hopin I could get by a little longer... YA didn't happen
Old 04-01-2015, 10:16 PM   #8
Jmustang78's Avatar
Region: Montana
Job cost $17/jnt and about an hour labor oh and U need the tool do not use socket and hammer!!!
Old 04-01-2015, 10:32 PM   #9
did it let go on the road...how fast
Old 04-02-2015, 08:03 AM   #10
Jmustang78's Avatar
Region: Montana
YA it let go on the road thank god I was in a parking lot about to park it went pop as I turned then when straightened out it went thunk and hit the ground. It's a good thing I wasn't goin down the freeway coulda been bad
K springs binding? Mikeyt03 2011-2014 Mustang GT 5 07-26-2013 09:16 AM
Is it a sticky limited slip or binding LCA? BlueDemon 2011-2014 Mustang GT 0 01-04-2013 08:04 AM
brake binding issue needs fixing fast!!!!! jkaminski24 1996-2004 Mustang GT 9 07-12-2009 12:02 AM
Odometer Stopped Turning Brent Pre-2005 V6 Mustang 7 09-14-2006 10:24 AM
No turning back now... Bane- Pictures and Videos 5 05-19-2006 08:36 AM
02:06 PM
