Maybe your battery is going.. Try checking the water levels in your battery. Check your battery or alternator at your local AutoZone they do it for free.
Not all battery's you can check fluid u have maintenance battery's and throw away battery's I have the same thing going wrong with my car except it's the solenoid
I had a similar problem when I had my 98v6 auto. I dropped the tank to replace the fuel pump and found that the screws backed out of the pump housing ( inside of the sump)causing the pump to lose prime. I left the old pump in tighten the two screws and that fixed my problem. Injector o-ring could be leaking and check your gas cap.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
