Suspension help - Mustang Evolution
Old 12-05-2014, 08:55 PM   #1
superdrift's Avatar
Suspension help
I scraped my roush front valence because i went over a hill to fast and the front went down but the wheels went up causing my front to barely scrap on a road. What can i change out to make my car not do that?
---------- Post added at 03:55 AM ---------- Previous post was at 03:54 AM ----------
Im sorry for not knowing how to explain this better
superdrift is offline   Reply With Quote
Old 12-06-2014, 07:49 PM   #2
Mile high JDF's Avatar
Stiff springs and stiff compression/rebound settings on your shocks
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-06-2014, 09:28 PM   #3
superdrift's Avatar
The am rep said that if i have adjustable shocks it would get rid of the problem
Old 12-06-2014, 09:57 PM   #4
It depends. Stiffening up the shock will help, but then the springs won't be moving at all. You want a set up to where both the springs and the shocks will work together.
Remember though, if you go over the same bump at the same speed with the stiffer springs and struts it will jerk the hell out of the car upward. That travel the wheels take softens up the ride, so the less travel there is the stiffer and stiffer it will be. Believe me, i have pretty stiff coilovers in my car, at least for street use.
Old 12-07-2014, 08:52 PM   #5
kickerofdoom's Avatar
Bigger tires
Suspension Make-over help blue-saleen Pre-2005 V6 Mustang 6 12-09-2009 07:18 AM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
suspension help tim11 Pre-2005 V6 Mustang 5 10-23-2005 02:53 PM
rear suspension need help fixing it... rpm Pre-2005 V6 Mustang 18 10-03-2005 07:01 PM
suspension help 35thAniVertible Pre-2005 V6 Mustang 23 10-31-2003 12:54 PM
07:11 PM
