Help? Stupid mistake 😩 - Mustang Evolution
Old 12-08-2014, 03:18 AM   #1
Its_vickk's Avatar
Ok so I have a buddy with a 95 v6 auto and he was driving his car in the rain and forgot to take off his cold air intake. So now he says his car idles weird like it drops to where it wants to almost shut off but it doesn't and it's blowing a bit of white smoke out of the exhaust. He also claims it's hesitant when accelerating. Any ideas as to what might be wrong?
Its_vickk is offline   Reply With Quote
Old 12-08-2014, 10:30 AM   #2
cozny's Avatar
Someon correct me if I'm wrong, but you can drive with a cold air intake in the rain, or even snow. I don't think it's the air intake that's the problem unless the filter sucked in a bunch of water and it got into the engine. You could try replacing the intakes filter if the filter got ruined.
cozny is offline   Reply With Quote
Old 12-08-2014, 02:42 PM   #3
phatmike's Avatar
Region: Nebraska
Yeah I don't really understand how water would get in there unless 1. He put it in a stupid place or 2. He drove through a foot of water because I've driven in the rain many times with mine and no problems
phatmike is offline   Reply With Quote
Old 12-08-2014, 06:17 PM   #4
cozny's Avatar
Can you be more specific, when you use the term white smoke?(how much smoke, does it come out for only a little bit or the entire time the engine is running , is it a deep smoke or light smoke, etc) be as descriptive as possible. Also are there any fluid leaks? When was the last time the car had a tune up?
Old 12-08-2014, 08:11 PM   #5
Its_vickk's Avatar
It was one of those days where it was pouring and streets were flooded that is why the filter got soaked. Light white smoke coming out of the tailpipe it only did that for the first 2-3 days and he said he heard a popping noise but that too has stopped. The only thing now is that it feels like it's hesitant when accelerating. No fluid leaks but he has changed the spark plugs and the oil just in case.
Old 12-08-2014, 08:26 PM   #6
Travis238's Avatar
Bad coil maybe. My 03 6 cyl had #2 cyl go out. My cats also got stopped up and made the car sluggish.
2005 Roush GT, Roush cai, BAMA 93r tune
Travis238 is offline   Reply With Quote
Old 12-08-2014, 10:34 PM   #7
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
If he sucked water in the intake he could have burnt a piston? Are there any check engine lights on? Run a computer scan on it! When he changed oil was it dis colored like chocolate milkshake?have him run an intake/injector cleaner (3 step kind).
Jmustang78 is offline   Reply With Quote
Old 12-09-2014, 05:23 PM   #8
coils, or the filter catched hell. Cold air induction is not about hiding from the rain or snow.
I have had those aftermarket cold air induction systems on all my cars (25 years passed by). Never seen them to fail me in that manner.
2012 GT 5.0 - MT82 - 3.55 rear axle ratio - Air aid CAI - Hypertech programming set to premium fuel - Borla ATAK exhaust system - BBK 90 mm TB - one piece driveshaft from DSS
*previous 2002 Trans Am GT 5.7L LS1
*previous 1994 Trans Am GT 5.7L LT1
*previous 1990 Taurus SHO 3L Yamaha Shogun
*previous : life was boring !
UP North is offline   Reply With Quote
Old 12-09-2014, 05:30 PM   #9
Travis238's Avatar
It sounds to me that the filter got wet and steam cleaned the inside of the engine for 2-3 days and clogged up the cats.
Old 12-09-2014, 05:54 PM   #10
cozny's Avatar
I would replace the filter, check to see if your cats are clogged, maybe now could be a good time for a tune up.
need help b4 i make a mistake 3.8-3.8 brettthom1422 Pre-2005 V6 Mustang 13 08-13-2012 03:13 PM
Need help to fix a mistake I made NitroLPR9 2005-2010 Mustang GT 17 04-28-2008 01:28 PM
Stupid Stupid Bonds bluemustang The Bar 8 02-07-2007 10:39 AM
Stupid stupid stupid!!!! lowflyn The Bar 10 10-23-2004 08:33 PM
Slight little mistake I made at work today Rellik The Bar 10 09-23-2003 07:17 PM
12:22 PM
