Stuck lean - Mustang Evolution
Old 12-09-2014, 11:25 AM   #1
Stuck lean
A couple days ago I plugged in my sct and saw the car had 2 pending codes. P2195 and P2197. Stuck lean.
I'm assuming this is the pcv valve or one of them at least. Or a vac leak. It was dirty where it connects to the oil case so I cleaned it up. But it's not difficult to lift it from its hole at all. Click image for larger version
Name:	ImageUploadedByMustang Evolution1418149120.956627.jpg
Is the thing replaceable? I'm looking online and I see kits that have 4 parts, where would the other locations be? I tried googling but I'm getting pictures of other engines as if mine never existed or something.
Has anyone else had these 2 codes?
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 12-13-2014, 11:40 AM   #2
That IS the pcv valve, and yes you replace it when it gets clogged and doesn't open/seal properly. It just pulls right out, the rubber gromet it sticks into is replaceable also, so that it is in there snug. Replace it someday and add an oil filter/separator.
Most likely not your problem.
***Replace that fuel filter, perform a Seafoam cleaning through pcv line or other vacuum line. Add 1 can of Techron to gas tank to help eliminate options or confusion for now.
***Check for cracked vacuum lines bundled around the EGR, firewall. The EGR pressure differential switch has vacuum lines to check also.
*** Mas Airflow Sensor (MAF) should be cleaned but ONLY with MAF spray cleaner, nothing else. Its located on your air intake close to air filter.
« 3.7l build | Oil »
1998 4.6 running lean on bank 1 and 2 eddie1 1996-2004 Mustang GT 22 11-28-2009 04:54 PM
left bank lean 98mustang2007 Pre-2005 V6 Mustang 1 09-17-2007 07:42 PM
Running Too Lean... MyStangStanks Pre-2005 V6 Mustang 11 10-16-2006 05:29 PM
Lean wit it lowflyn Pictures and Videos 9 09-14-2006 10:47 AM
lean back STEVE The Bar 22 12-21-2004 11:50 AM
08:24 AM
