Spark plugs! - Mustang Evolution
Old 12-12-2014, 06:40 PM   #1
Zinc's Avatar
Spark plugs!
Where are the 2002 mustang v6 spark plugs located ?
Zinc is offline   Reply With Quote
Old 12-12-2014, 07:28 PM   #2
Behind the fire wall
Old 12-12-2014, 07:29 PM   #3
Zinc's Avatar
Is there a picture possibly?
Old 12-13-2014, 10:15 AM   #4
Mobley's Avatar
Try youtube. Lol
Sent from my SGH-M819N using Mustang Evolution mobile app
Mobley is offline   Reply With Quote
Old 12-13-2014, 10:38 AM   #5
yellowconve's Avatar
just follow the spark plug wires silly and you can change em all ur self in like a hour just dont disconnect them all do them one by one cause you dont want to mix the wrong wires to its wrong location need help pm me
yellowconve is offline   Reply With Quote
Old 12-13-2014, 10:46 AM   #6
Mobley's Avatar
Also take off your cold air intake makes it easier
Old 12-13-2014, 10:51 AM   #7
When u open your hood, you will see a "Ignition Coil Pack" , center top of engine. The wires to the top of the coil pack go to each of the 6 spark plugs. One at a time, trace each wire from coil pack to either side of engine. Gently twist then pull the wire boot off. One wire is off, plugs are threaded inside of engine block. Use socket with short extension and remove, install new plugs with firm tightness, but do not over tighten.
This is picture of your coil and plugs:
This is a picture of plug location and spark plug wire boot:
Use Motorcraft, Autolite, or NGK plugs. Copper work best, Platinum last longer.
Old 12-13-2014, 11:08 AM   #8
These cars don't have spark plug wires. They have Coil On Plugs.
The spark plugs are located underneath the COPs which are on top of the engine near where the intake manifold meets the cylinder head. There is one COP and one fuel injector next to one another for each cylinder. The COP is the larger of the two cylindrical shaped objects and it doesn't have the chrome fuel rail sitting on top of it.
The spark plugs are very easy to change on these engines but I must caution you to not over tighten them! That is the number 1 cause of spark plug blow outs. Make sure that you use a torque wrench to tighten them!
There is a thread, on the last page of he DIY tech forum, that outlines the procedure and has the torque specs.
Old 12-13-2014, 11:11 AM   #9
Lol.
I thought this was the GT forum!
Disregard everything I just said!
Carry on fellas!
Old 12-13-2014, 11:11 AM   #10
uhh yeh but the guy asking is a 2002 mustang v6 its from the distributer to the wires to the engine and remove the cold air intake like some one said make it way easier and also make sure got the right tools a spark plug socket will be needed.
Old 04-01-2015, 08:51 PM   #11
its a distributorless ignition yellowconve......no distributor
99whitev6 is offline   Reply With Quote
Old 04-02-2015, 01:43 AM   #12
Iryan7's Avatar
I needed to use my swiveling socket to reach one or two on the pass side. Start with the drivers side because it is much easier over there. +1 to whoever suggested removing your CAI or factory air intake. I don't see it being possible without doing so. For future reference, here is a diagram of the firing order in case you need it: Click image for larger version
Name:	ImageUploadedByMustang Evolution1427960592.706365.jpg
ID:	178869 I believe the middle diagram is the one you would want to refer to.
Iryan7 is offline   Reply With Quote
Old 04-10-2015, 05:22 PM   #13
SueK's Avatar
What the Hell? Three on one side of the motor and three on the other. Firewall? Where do you put your gas in the radiator?
SueK is offline   Reply With Quote
Old 04-10-2015, 05:29 PM   #14
I'll be more than happy to answer that. I put it in the power steering pump. I actually put lemon lime gatorade in the radiator
Old 04-10-2015, 05:31 PM   #15
SueK's Avatar
Three on one side, Three on the other. YOU CAN'T MISS THEM. Coil on plug are for GT's. His V6 has a coil pack. You follow the wires from the coil pack to the plug. COIL PACK http://1.cdn.lib.americanmuscle.com/...g-wires-07.jpg
Old 04-10-2015, 05:33 PM   #16
SueK's Avatar
Good I thought you were going to say Red Bull.
Old 04-12-2015, 10:40 PM   #17
lemons95's Avatar
haha, I got a few laughs from this post.
Yeah though, 3 sparks plugs on each side. 6 in total
Follow the wires from your coil pack and do one wire at a time, do not get them mixed up. each wire needs to plugged into a certain location
I just recently replaced my coil pack, spark plug wires and spark plugs. definitely feels a bit more responsive.
Maybe it's just because I had to suffer and drive to work for a few weeks with a bad something. I just said **** it, and bought everything since the coil pack was the original from 1995, and the spark plugs and wires were 5 years old from when I first bought the car.
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 08:42 AM
No spark in the spark plugs 94GTpony 1979-1995 Mustang GT 7 10-30-2012 01:20 PM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 03:20 PM
Spark Plugs Stang01 Pre-2005 V6 Mustang 19 07-18-2003 04:55 PM
10:37 PM
