Vibration at idle when engine first starts - Mustang Evolution
Old 12-12-2014, 09:14 PM   #1
Iryan7's Avatar
When I start my engine, my car vibrates pretty bad. After a few minutes it evens out and has zero to a few vibrations. 2001 3.8 with 177,737 mi. on it. Did spark plugs over the summer. Any help would be great.
Iryan7 is offline   Reply With Quote
Old 12-13-2014, 11:11 AM   #2
On engine start up, look, listen for broken vacuum lines. They are fragile and most all crack eventually. They run across the firewall colored black, red, brown. If big enough leak, then spraying a mist (aerosol carb cleaner, Seafoam spray, ect..)near the crack will show itself.
A full PM is always helpful at eliminating any guesses.
-Clean air filter, MAF sensor, clean intake. (Seafoam treatment through vacuum lines once a year helps)
I even added a home made oil filter/separator inline with PCV system.
-New fuel filter. (once a year for me)
-Could be a leak that is effected by expansion/contraction of the engine.
-Seafoam is great for cleaning intake. Techron is the best made for adding to gas tank. Perform treatments shortly before oil changes.
Old 12-13-2014, 02:13 PM   #3
Iryan7's Avatar
Thanks, I'll clean my CAI and MAF sensor and let you know if it helps. I think it might be a bad hose somewhere, so I'll check that out too.
Old 12-13-2014, 05:16 PM   #4
Seafoam dat bioch. Get a can a Seafoam, a straw, suck some in very slowly through pcv line into intake. Techron treatment in gas tank.
-Those two will only give good help, help diagnose easier, fuel filters are cheap & simple to swap out.
Vibration when car starts phatmike Pre-2005 V6 Mustang 5 10-19-2014 10:21 AM
Starts fine but refuses to idle deltadart11 Pre-2005 V6 Mustang 3 02-26-2013 05:54 PM
2001 mustang vibration at cold in reverse and first gear Marco Pre-2005 V6 Mustang 6 08-13-2012 09:31 AM
First Post, First Car, First Mustangg EdgeLivin New Member Introductions & Greetings 14 04-03-2012 12:49 PM
Shattering noise and vibration when engaging the clutch only on first gear and reverse? wolfe General Mustang Discussion 3 03-10-2010 05:40 AM
09:45 AM
