Cracked Head or Head Gasket problem - Mustang Evolution
Old 12-12-2003, 06:17 PM   #1
Car dealers in this area will not touch Mustangs, T-birds or cougars with 3.8 v6's in them as they say that the engine has problems with the heads or head gasket problems. Can anyone help me out?
Thanks,
DMustanger is offline   Reply With Quote
Old 12-12-2003, 06:37 PM   #2
In short, don't deal with dealers that stupid or ignorant.
In long, the 94-95 had gasket problems that caused alot of problems. That is it.
To your issue, how will they not touch them?
Won't fix your car, buy your car, change the oil because of head problems? What are you trying to get done?
Extreme Effects.com is offline   Reply With Quote
Old 12-13-2003, 06:19 AM   #3
I have a chance to buy another 95 and I am trying to decide if I should. The 95 V6 that I have now has not had any problems. When you say that they have had alot of gasket problems, which ones and how do you correct the problem?
Thank you,
Old 12-13-2003, 07:38 AM   #4
RGR
Send a message via AIM to RGR
Basically all of them when you start adding HP,
but that is a good excuse to pull the heads and
get ported ones, and change the cam and intakes
at the same time!
I have heard of hi-mile 94-95 stangs not having HG problems,
but they were drove really easy and not subjected to HP adding
stuff. UDP's and CAI would not really hurt anything, but driving
it hard will stress the HG's and probably make them give out.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 12-13-2003, 11:52 AM   #5
Danger Dude's Avatar
It was just not 94-95 mustang but all Ford cars and vans from 89 to 95 with the 3.8 motor with the except the T bird SC. Ford fixed the head problems early in 96 and 97 and up had no problems at all. Iwas was a combination of problems. One problem was the head gaskets the other was the water jacket design had holes to close to the cylinders. The head changed fixed it for good. As Robert said owners that seemed to have no problem soon did when they add performance parts and drove their cars harder. Erick (EVal) had problems as soon as installed his Supercharger
Old 12-13-2003, 12:42 PM   #6
RGR
like we told him it would!
Old 12-13-2003, 12:51 PM   #7
and he did not listen the BLOCK HEAD
Old 12-13-2003, 01:33 PM   #8
RGR
I think he just wanted the excuse that he had to
change his HG, cuz his momma would not let him!
Old 12-13-2003, 08:35 PM   #9
MUHAHAHAHHAHAHHAHA
Old 12-13-2003, 11:37 PM   #10
Dom
Dom's Avatar
Send a message via AIM to Dom
Re: Cracked Head or Head Gasket problem
Thanks,
If your really worried about it, take it to a engine shop and tell them to throw on some Fel-Pro Headgaskets and some APR Head bolts.
Old 12-14-2003, 10:53 AM   #11
OEM 99+ head gaskets > felpro
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 12-14-2003, 12:31 PM   #12
Dom
Dom's Avatar
Yea don't rub it in.
Old 12-14-2003, 01:06 PM   #13
Supercoupe gaskets> 99+ gaskets>Fel-pro
Old 12-14-2003, 01:17 PM   #14
what makes SC gaskets special???
New Hottness
1999 V6 5-speed
Wrecked
Old 12-14-2003, 02:32 PM   #15
Dom
Dom's Avatar
I guess thet were meant to hold a little more power.
All I really know about head gaskets are that they are the most important gasket on the entire engine.
Old 12-15-2003, 08:04 AM   #16
there are lots of "important" gaskets.
Head gaskets are meant to hold the most pressure/beating than any others. Thus why the 99+ ones are 3 layer metal gaskets. and most others on the engine are paper/rubber.
New Hottness
1999 V6 5-speed
Wrecked
Old 12-15-2003, 09:10 AM   #17
Well for nitrous and supercharger or for plain beefy application SC head gaskets are the best. Go get them at any Ford dealer
Old 12-15-2003, 11:01 AM   #18
lol but WHY. What makes them the best. Not "just because"...
Not many people have blown 99+ head gaskets. The few that have (milan) experience their heads lifting and then blowing the gasket....which means they have more problems other than a gasket.
New Hottness
1999 V6 5-speed
Wrecked
Old 12-15-2003, 11:58 AM   #19
Well Mikael, Pete as well as 3 Ford mechanics told me they would hold up best. With you having Mikael's Heads he did not tell you about the gaskets
Old 12-15-2003, 02:56 PM   #20
no. I specified OEM instead of the fel-pro's he carries.
Im not doubting you Im just wondering what actually makes them stronger.
New Hottness
1999 V6 5-speed
Wrecked
Old 12-15-2003, 05:34 PM   #21
Will a 3.8 from a 97 mustang fit in a 95 without any modifications. In other words will the intake and everything else from the 95 bolt on. My 95 has 98,000 miles in it and I would like to put in a new rebuild.
Thanks
Old 12-17-2003, 06:52 AM   #22
Yes they will bolt up. There is a few differences in where the Vacume lines hook to the upper intake but they are interchangable. I have a 94-95 Upper on my 98 motor and had to buy a couple of "T's" for the vacume lines to attach.
Head Gasket ?s 95-3.8 cgff Pre-2005 V6 Mustang 4 01-27-2010 08:17 PM
head gasket replacement on 04 GT mikeg 1996-2004 Mustang GT 6 12-03-2009 08:56 AM
head gasket... on a seabring? jimmy_beaner The Bar 6 05-06-2008 08:07 AM
leaking head gasket tedness Pre-2005 V6 Mustang 5 03-07-2005 10:06 PM
leaking head gasket...what? tedness The Bar 1 03-07-2005 09:43 PM
11:02 PM
