Turn signal flashes fast after halo light install - Mustang Evolution
Old 12-20-2014, 10:35 PM   #1
Iryan7's Avatar
While wiring the halos on my projector lights, we tried to make it look good on the wires and put it in the plug (plugs wires into the turn signal). Long story short it didn't work and that plug messed up. The wires are temporarily hard wired into the light socket. There were a few sparks during the process. Everything does work, but the pass side turn signal blinks very fast. We did the drivers side the easier way and spliced it. Everything works perfect for the drivers side, no fast turn signals. This bothers me on multiple levels because my sequential tail lights look stupid when I turn right. I plan on replacing that plug that holds the wires (plugs into the turn light) in the next few days and seeing if that fixes it. If anyone has ANY information that would help me, please do share. Picture of the plug below: Click image for larger version
Name:	ImageUploadedByMustang Evolution1419140051.205022.jpg
ID:	172297Click image for larger version
Name:	ImageUploadedByMustang Evolution1419140152.959254.jpg
Iryan7 is offline   Reply With Quote
Old 12-21-2014, 06:55 AM   #2
Iryan7's Avatar
Could this be because I need a new lamp socket? If anybody has any info I would really appreciate it
Old 12-21-2014, 09:38 AM   #3
natestang07's Avatar
*I know nothing about wiring*
now that I have that out of the way I recall reading that if you don't have a resistor of a proper size it led lights will flash normal than they are supposed to.
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 12-21-2014, 10:10 AM   #4
Iryan7's Avatar
Only thing is I don't have led bulbs, and only the right side flashes faster. I'm rewiring a new turn signal switch connector today when I get a chance
Old 12-21-2014, 10:15 AM   #5
Well then other goes that theory lol. Only the one side sparked though?
Old 12-21-2014, 10:27 AM   #6
Iryan7's Avatar
Yeah, I just used connectors on the drivers side. Made it easier and safer.
Old 12-21-2014, 10:30 AM   #7
Yep sounds like you are on the right track to fix it, good luck and let us know how you make out!
Old 12-21-2014, 03:58 PM   #8
Iryan7's Avatar
Update: the light started blinking normally again today. I did nothing to it and have no idea why it fixed itself. I did however rewire and replace the turn signal switch connector (had it temp. Hard wired in) because It would have messed up eventually. Everything works great now.
Old 12-22-2014, 02:55 PM   #9
Iryan7's Avatar
Update: the fast flashing is back. It randomly started while driving home today. Anybody has any idea why please inform me
Old 12-22-2014, 04:40 PM   #10
Iryan7's Avatar
Alright, so I'm the dummy of the thread. I had a bad bulb in my sequential tail lights. Replaced the bulb and everything works as it should. For now at least
turn signal prob gearbanger67 Classic Mustangs 2 10-09-2007 08:37 PM
Need some help.. when key is on the ON postion check engine light flashes Brent Pre-2005 V6 Mustang 11 11-14-2006 12:23 PM
O/D Off flashes on and off Brent Pre-2005 V6 Mustang 24 12-23-2005 05:37 PM
Jump out and scare you Flashes Ken The Bar 6 12-21-2005 06:07 AM
Sequental Turn signal Discount till the 9th!!! Rellik Mustang Audio & Video 2 11-10-2003 11:04 AM
06:41 PM
