2000 V-6 Cranks but won't fire - Mustang Evolution
Old 12-21-2014, 07:42 AM   #1
Several weeks ago my 2000 v-6 would crank but not fire. Determined there was spark but couldn't hear the pump from inside. I removed the gas cap, turned the key to the on position, ran around to the fuel filler hole to listen and still heard nothing. I thought I wasn't getting to that side in time so asked a helper to turn the key to the on position as I listened. I still didn't hear anything so I resolved myself to going to get a new pump and put the cap back on. As I walked around to retrieve the key, the helper cranked the car and it fired right up. I struck the pump off the list, concluded there was a vapor lock or cap pressure issue and I drove to the nearest parts store and got a new cap. All was well in the world.
Unfortunately, the same thing has started happening again. This time removing and replacing the Fuel Cap didn't work. I have not tried a different "new" cap but before I do that again, replace the filter, or ultimately get in over my head replacing the pump, I was wondering if anyone had any advice.
jbow is offline   Reply With Quote
Old 12-22-2014, 09:05 PM   #2
baddbradd's Avatar
I wonder if its the fuel pump module...not sure but maybe you can look into that
2001 coupe
baddbradd is offline   Reply With Quote
Old 12-25-2014, 09:21 AM   #3
Thanks Brad. Checked everything, but I still didn't hear the pump nor did I get any pressure. I removed the filter, replaced it, and it fired right up. I did some experimenting on the old filter and I couldn't get anything to pass through without first banging it around. So, the Pump must have figured it was providing the pressure it should have been and took a union break and that's why I didn't hear it.
89 GT cranks every time but won't start MOST TIMES! HELP!! Red89 1979-1995 Mustang GT 43 01-28-2014 04:35 PM
Cranks but wont start dg3adidas 1996-2004 Mustang GT 6 04-16-2013 06:31 PM
Mustang cranks but doesnt start Jamesgt08 1996-2004 Mustang GT 24 03-13-2011 09:31 AM
1995 GT cranks but no start hot 89beretta 1979-1995 Mustang GT 9 07-26-2009 08:23 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
02:46 AM
