Serious problem... Car jerks lol - Mustang Evolution
Old 12-24-2014, 06:19 PM   #1
So my car has been acting weird lately (2003 v6 auto 130k miles [no mods]) so when I'm driving the car jerks like it moves you back and forth. This happens at highway speeds or when i try to gun it. I checked the transmission fluid while hot and its still red not bright red but its also not black. I read on other forums and mention a bunch of diferrent ideas but nothing solid. Anyways since i took ownership of the car i changed the plugs, wires, belt & air filter about a year & half ago also I changed the fuel filter a couple months ago. Does this sound like a tranny problem or something else
Any help is appreciated
Old 12-24-2014, 06:33 PM   #2
Tyoung68's Avatar
Sounds like my moms expedition right now and it was because her sparkplugs were backing out
Killing time isnt murder, it's suicide
Old 12-24-2014, 06:45 PM   #3
Sounds possible because it does feel like it misfires
Old 12-25-2014, 08:55 AM   #4
Anyone else have any suggestions
Old 12-25-2014, 11:30 AM   #5
rocknbronco's Avatar
Is it throwing any check engine code?
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 12-25-2014, 01:37 PM   #6
No light but i haven't had it scanned since i know there might be a code but no light
Old 12-25-2014, 02:06 PM   #7
Tyoung68's Avatar
My moms car didn't have a CEL at first only came on after it got really bad
Old 12-25-2014, 02:16 PM   #8
I'll have to wait till tomorrow the thing is I'm scared it might be the tranny. If it is going to throw a light I need to fix it asap cause its do for emission testing
Old 12-26-2014, 07:28 AM   #9
I dislike emissions
Old 12-26-2014, 04:15 PM   #10
EverettsV6Power's Avatar
I just took a 1600 mile round trip to fl and my car seemed to be doing the same thing near the very end like it was surging/ stuttering I hope it goes away not sure what it is but haven't been in it since
EverettsV6Power is offline   Reply With Quote
Old 12-26-2014, 05:01 PM   #11
Probably a bad miss fire I ran two cans of Sea Foam through my truck today and it's doing the same thing. On a humorous note the neighbors came across the field and investigated why it looked like my house was on fire....
Old 12-26-2014, 05:28 PM   #12
Just try changing the plugs anyway. Or pull one and see what it looks like. It will tell you a lot about what's going on with the car. It's not that much anyways
Judge_dredd is offline   Reply With Quote
Old 12-26-2014, 09:11 PM   #13
I'm trying seafoam tomorrow maybe. Before i washed the car today i pushed the wires in the coil pack just to make sure they're not loose. I also topped off the oil since it has a small leak. Since I live right off the freeway I took it for a drive and pretty much drove it like I stole it and no issues at all. If it acts up again I'll get it scanned, seafoam it, change oil and put 91 since gas is cheap (placebo effect) if all fails then I'll suck it up till next pay period & change the spark plugs since this is rent check lol
Old 12-26-2014, 10:02 PM   #14
Tyoung68's Avatar
You dont necessarily need to change the plugs, my moms literally came unscrewed i just re tightened them
Old 12-26-2014, 10:20 PM   #15
So is it only the V8s that Shoot out of the block?
Old 12-26-2014, 10:21 PM   #16
Tyoung68's Avatar
Idk I never really new about that problem
Old 12-26-2014, 11:16 PM   #17
I've never seen it either but have read about it here
Old 12-27-2014, 12:02 AM   #18
Damn!! Rent is coming up again
I feels like I JUST payed this months rent..
Oh wait...
Old 12-27-2014, 01:00 AM   #19
Old 12-27-2014, 05:37 PM   #20
Not trolling at all. Rent blows lol
Old 12-28-2014, 04:32 PM   #21
So the problem came back and i took it to the autozone lol and no codes showed up except for the abs but thats been ****ed up since i bought it. Can I rule out the transmission? If i will need one can i get one off a GT?
Old 12-30-2014, 08:29 PM   #22
Why would you want a GT tranny for a stock v6?
Does the jerking occur when the car shifts? you should look at your ignition coil if its the original one
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 12-30-2014, 09:14 PM   #23
Yea its the original one. Oh and i was wondering since most junk yards & people parting out their mustangs are mostly GTs. I wasn't planning on getting it for "performance" reasons but because thats what i could find. I also spoke with a friend that has a 01 civic and said that her car is doing the same and that thr honda dealership told her it could be her torque converter
Old 12-30-2014, 09:48 PM   #24
That's a Honda NOT A FORD.
Old 12-30-2014, 10:00 PM   #25
Yes i know but i figured a transmission is a transmission lol
Old 12-30-2014, 10:48 PM   #26
Do a fuel pressure test.
Old 12-30-2014, 11:04 PM   #27
What psi should it be at
Thanks all for the help. I really like this car and don't want to give it up
Old 12-30-2014, 11:24 PM   #28
The fuel pressure should be between 35 to 55 psi at idle. After the key is turned off, it should lose no more than 5 psi after sitting for 5 minutes.
Old 12-30-2014, 11:44 PM   #29
Ok. I'll post results tomorrow if autozone loans the tool. I looked at a couple youtube videos and it looks pretty straight forward
Old 12-31-2014, 05:22 PM   #30
SueK's Avatar
Maybe a bad fuel pump? If you don't have a CEL lit going to Autozone won't help. Unless you have a bulb out for it. Also when you get readings sometimes it'll say for example " EGR" It could not the EGR itself, It could be a component that has to do with it. I hope you find out what it is. How about your fuel filter? If you have a clog it'll buck.
SueK is offline   Reply With Quote
Old 12-31-2014, 05:42 PM   #31
Well the fuel filter was changed around april or may so I doubt it could be that plus i used a motorcraft brand not an autozone generic filter. Idk how to test a bad fuel pump but the car starts with no problem. I drove it on the streets today with no problem but once i got on the freeway it started again. I have yet to do the pressure test
Old 01-16-2015, 03:04 PM   #32
Ok so update to this. I took it to the mechanic and while inspecting it one of the spark plugs cracked. Also he said that he recommends to do a decarbon the motor. I got quoted 300 including parts and labor. So is the decarbon treatment just seafoam?
Old 01-16-2015, 03:08 PM   #33
It is if you use just Sea Foam and it will cost like 40.00 at most if you Sea Foam it yourself.
Old 01-16-2015, 03:11 PM   #34
Ok then thug life I'd rather do that also he said something about it running high compression cause of this? Anyways this is good news
Old 01-16-2015, 03:16 PM   #35
SueK's Avatar
The same thing. Watch some Youtube video's, That what I did. Parts meaning plugs? Whew. The labor is killing you on that one I bet. Total bull. I'm 55 and I did all that stuff myself.
Car Jerks, Sluggish Tach Jumps And It Has a Code 56 mike_jay5.0 1979-1995 Mustang GT 2 07-08-2013 07:41 AM
93 Bama Race Tune - Car Jolts/Jerks Buckeye80 1996-2004 Mustang GT 10 03-20-2013 10:02 PM
Car feels like it jerks and makes a clunk noise at low rpms Adamp1 2011-2014 V6 Mustang 4 03-12-2013 12:10 PM
Serious Problems Need Serious Help Red Stallion 11 2011-2014 V6 Mustang 18 08-02-2012 06:30 PM
07:46 AM
