2004 V6 3.8L - Cyl. 1 misfire code - Mustang Evolution
Old 12-26-2014, 01:45 PM   #1
I know a bit about cars, but still learning to fix my own. I have a 2004 V6 3.8L Mustang. I was driving the other day and the Service Engine Soon light came on. I checked the code and it said that I had a "Cylinder 1 misfire". I changed the plugs and wires the next day. It ran great for a while but now the code light is back on, flashes at times, and the power drops off. The A/C also started blowing warmer air until the flashing stopped. Any thoughts??
badwolf2010 is offline   Reply With Quote
Old 12-26-2014, 04:25 PM   #2
cozny's Avatar
How old is your coil pack?
cozny is offline   Reply With Quote
Old 12-27-2014, 06:38 PM   #3
LaserRed99's Avatar
Yeah, probably ignition coil.
'03 Mach 1 5spd
Fully forged Manley rods/pistons, Cobra crank, ARP hardware, 8.5:1, Procharger P1SC w/ intercooler, AFM power pipe, 60# injectors, 03/04 Cobra tank with dual fuel pumps, Kenne Bell Boost-a-Pump, O/R X pipe and Flowmasters, Exedy stage 3 clutch, Steeda Tri-Ax, Front and rear upper + lower control arms, Ford Racing springs, Bob Monks tune 448 rwhp @ 9 PSI
LaserRed99 is offline   Reply With Quote
Old 12-28-2014, 12:39 PM   #4
irishn8's Avatar
It put ur engine in limp mode FYI - no A/C, limited power, blinking CEL
Old 12-28-2014, 06:28 PM   #5
cozny's Avatar
What's limp mode?
Old 12-28-2014, 10:25 PM   #6
irishn8's Avatar
Fail safe mode/limp home mode is your EEC trying to protect itself, the engine, and transmission from further damage when it detects something that could cause catastrophic failure.
In your case reducing power will preserve your engine, if it didnt and you floored it while missing, you could have compression ignition (diesel effect) firing at the wrong time, causing burnt valves, blown gaskets, etc.
Misfire code BenGT07 2005-2010 Mustang GT 18 11-13-2012 07:24 AM
Clutch replacement #4 cyl misfire gregtommy 2011-2014 Mustang GT 29 05-22-2012 08:52 AM
Misfire on #5 code vwdavid Pre-2005 V6 Mustang 11 01-21-2011 11:00 AM
check engine light misfire code 98stang460 1996-2004 Mustang GT 6 07-27-2010 08:27 AM
I need some advice ... i keep getting code p0300 random misfire? cruz Pre-2005 V6 Mustang 1 03-22-2010 10:29 PM
04:14 AM
