Transmission Help - Mustang Evolution
Old 12-26-2014, 10:59 PM   #1
PRoss.20's Avatar
Region: Arkansas
Transmission Help
I think my car (2004 v6) is putting out about 280 horsepower and I read somewhere that the stock automatic transmission can only take 40 or so more than stock. Also, since I had a transmission shift kit installed it's seemed to start having some troubles shifting properly or slipping sometimes. I was wondering if this is because of the amount of horsepower I am putting out is being hard on the transmission and I need a new one? Also, if I got a new one I would need a GT transmission for my horsepower? But the GT transmission won't fit with a v6 motor. So basically should I look for a new v6 transmission or should I just try and make it last until I have the money to just swap the engine and the transmission at the same time? I'm just worried about the v6 transmission going out on me before I have the money to swap it all. Thanks for any ideas, comments, or advice!
PRoss.20 is offline   Reply With Quote
Old 12-26-2014, 11:18 PM   #2
natestang07's Avatar
What do you have done to be putting out that much power?
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 12-27-2014, 07:29 PM   #3
PRoss.20's Avatar
Region: Arkansas
210 horsepower stock, CAI, throttle body, off-road xpipe, flowmaster exhaust, GT rear end with 3.73 gears, with Bama tune. Just going off the estimated gains from everything, running higher octane fuel, and the performance tab from the Bama tune app I have which said 300+ hp when I tested it but I figured that would overestimate.
Old 12-27-2014, 07:34 PM   #4
Rapinator126's Avatar
Are these post real???
I hurt from laughing so hard right now.
Old 12-27-2014, 09:20 PM   #5
I would say you are putting out 200-220 to the wheels
Old 12-28-2014, 11:59 PM   #6
PRoss.20's Avatar
Region: Arkansas
Yeah to the wheels, but more than that is going to the transmission. the transmission isn't rated on how much horses a car puts to the wheels.
Old 12-29-2014, 12:01 AM   #7
PRoss.20's Avatar
Region: Arkansas
Great help!
Old 12-29-2014, 12:17 AM   #8
Originally Posted by PRoss.20 View Post
Great help!
Your stock transmission can handle the power level you are at no problem. Try changing the fluid to pen oil synchromesh at 3.2 qtz. It is probably just over filled
Old 12-29-2014, 04:12 AM   #9
PRoss.20's Avatar
Region: Arkansas
Thanks man, I'll try that.
Old 12-29-2014, 05:25 AM   #10
kingstrider's Avatar
Sounds like this is your problem, not a few extra ponies from a couple of bolt ons. I would take it back to whoever installed the kit and make them fix it.
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 12-29-2014, 06:37 AM   #11
Mile high JDF's Avatar
He has an auto so this fluid won't work in it
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-29-2014, 07:32 PM   #12
PRoss.20's Avatar
Region: Arkansas
Well I still will check the fluid level
Old 12-29-2014, 07:34 PM   #13
I missed that part thanks JDM lol
Old 12-30-2014, 01:33 PM   #14
If the issues started when the shift kit went in then I'd bet the person who put it in boogered it up. I'd take it back to them and tell them they messed something up.
As for your power... car is in no way close to 280. They are stock 195, the 4.0L makes 210. With your mods you are probably making 190-200 to the rear wheels. Adding up the advertised mod power gains (always exagerrated) and adding them to your crank HP is called "paper horsepower" and is never right.
Like I said, take the car back to the shop that did the shift kit and see what's up. Transgo has issues relatively often if that's the kit you used. Most ppl with 4R70ws (what you have) just J-mod them which is better and cheaper than a shift kit and has the added benefit of increasing transmission life.
Oh, as far as the 4R70w trans, they are good for way more power than you are making. Even if you were making 300 wheel hp it wouldn't even be breaking a sweat.
Also, have you had your tune re-burnt since you put the shift kit in? Bama is not the greatest tuner in the world but they should be able to adjust your shift points.
Old 12-30-2014, 05:19 PM   #15
PRoss.20's Avatar
Region: Arkansas
Ah, I thought I read somewhere the 3.9L took it up to 210 but maybe it was 200? Also, when they installed the shift kit they also installed a deeper transmission pan. First time after installation I had to take it back because it would slip if I gave it any gas at all. Turns out they didn't hook something up right so they fixed that, but they also had a lot of trouble getting the fluid to the right level but it was completely fine for a while after I got it back the second time but I guess maybe the fluid level is just off by a little bit and wasn't noticeable at first? It was the shift kit american muscle sells with the new valve springs and plates I believe. I did have it retuned after I had the kit installed.
I guess lots of people disagree how much HP the trans can take? I've seen some people say 40 over stock to 100 over stock. My bad though I thought they meant power to the crank not to the wheels.
Old 12-30-2014, 05:42 PM   #16
Welp, if the trans was fine before these goobers had to take two tries to install a shift kit... 2+2=4.
Old 02-04-2015, 06:01 AM   #17
madman99's Avatar
Transmission Help
Will I be able to put a Tremec t56 tranission in my 99 new edge? Will there be any fitment issues ? #help
madman99 is offline   Reply With Quote
Old 02-05-2015, 11:35 AM   #18
No they bolt right in but it may not be the best choice because of the gear ratios in the T-56 if your Mustang isn't making enough torque or doesn't have steep enough gears.
Old 02-05-2015, 04:10 PM   #19
madman99's Avatar
I was looking around I'm doing a coyote swap n eventually throwing turbos on it so I. Red something that'll hold
Old 02-05-2015, 06:22 PM   #20
What is your goal with the car? If you are already auto then just get a properly built 4R70w and then when you go to the Coyote you can install a manual controller. A good 4R will hold a ton of power.
Old 02-05-2015, 08:09 PM   #21
madman99's Avatar
Isn't that a trans in a f-150? And my plans are to have a road coarse street car to play with
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
Pleasee help me, transmission change Steelerdude90 Pre-2005 V6 Mustang 3 07-17-2008 10:43 AM
transmission stuck in 3rd gear need help theglory 1979-1995 Mustang GT 18 02-15-2006 10:20 AM
Need help with transmission *Pictures* Brent Pre-2005 V6 Mustang 8 12-12-2005 03:07 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
02:57 AM
