Transmission Problem - Mustang Evolution
Old 12-27-2014, 09:23 PM   #1
I have a 99 mustang with a 3.8 engine and auto transmission. The other day it started not wanting to go into drive. You could rev the engine up and it would take hold and work fine. It would switch gears with no problem. When I would stop I would have to rev the engine up again to get it going and then it would work fine again. Now it want go at all except in reverse. It will go into reverse with no problems just won't go forward.
tnriche is offline   Reply With Quote
Old 12-28-2014, 12:29 PM   #2
irishn8's Avatar
Check fluid. If fluid level is ok then have tranni serviced
Old 12-29-2014, 12:36 PM   #3
Fluid is good. I changed the filter and fluid when it first started acting up but it didn't make any difference. I figured I would have to put another transmission in it.
Old 12-29-2014, 01:09 PM   #4
cozny's Avatar
When you replace your filter it only removed about 4 quarts. When you have your transmission serviced they basically pump new fluid through the entire transmission, until all the old fluid has been completely removed. There's is about 11.5 quarts of fluid in the entire transmission most of which is in your torque converter. Replacing the filter only removes about 4 quarts of fluid that's in the transmission pan.
cozny is offline   Reply With Quote
Old 12-29-2014, 01:17 PM   #5
cozny's Avatar
And define rev the engine? By that did you mean you had delayed engagement? Delayed engagement could be caused be lots of things. (Most likely your 1st gear transmission band needs replaced.) if you forced your transmission into gear while its having an issue building up pressure for first gear, that could definitely have destroyed your band, and will need rebuilt. If it works with reverse right away it's more and likely not a pressure problem though. Since the transmission needs the most pressure in reverse. Has the car ever been tuned?
Old 12-30-2014, 12:32 PM   #6
Reverse works perfect, just as soon as you put it in reverse it will take hold. Yes you had to rev the engine and then 1'st would take hold and it would work fine until you stoped. Then you would have to do it all over again. It's actually my sons car and we haven't had it very long. The original engine had droped a valve so I replace it. As far as I know it hasn't been tuned. I will probable just put another transmission in it.
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
Transmission problem.... I think...HELP! BbV06Stang Pre-2005 V6 Mustang 8 06-07-2009 10:59 PM
transmission problem..2006 v6 jackwhite General Mustang Discussion 4 05-21-2009 04:21 PM
Transmission fit problem claytonbeaver Classic Mustangs 2 05-05-2009 09:17 AM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
08:15 AM
