Stutter after long trip - Mustang Evolution
Old 12-28-2014, 04:33 PM   #1
EverettsV6Power's Avatar
So I just got back from a long Christmas trip and now I am having some problems my cats have clogged up and I'm having a Cyl. 3 misfire question is my plugs are a month old so I hope that's not the problem could the clogged cats file out my plug? Idk what to really go check the car is stuttering real bad and has lost a stupid amount of power thanks
Sent from my PLT7050 using Mustang Evolution mobile app
EverettsV6Power is offline   Reply With Quote
Old 12-29-2014, 02:40 AM   #2
irishn8's Avatar
Its possible i suppose, but not likely. It would be more likely that it were the other way around - misfiring can clog cats. Try swapping the plug and wire to see if the misfire moves to the cylinder that you swapped them to. If it doesnt move, check for spark from the coil pack. If everything is good then check the injector by removing the plug from the cylinder and crank the engine over a few turns and see if you can smell fuel coming from the cylinder. If everything is good so far then id say that your cats are so plugged up that its choking the engine.
Old 12-29-2014, 11:00 PM   #3
Thank you I'll run through all that in the morning wasn't sure where to go
Old 12-30-2014, 09:16 PM   #4
mazen123's Avatar
This is an excuse to get an off road X or H pipe lol. I had a cat clog up 2 weeks ago and the first thing I did was buy an off road pipes X pipe from american muscle and I put it on. Nice and loud and throaty now with the flowmaster super 44s out back, got it tuned from bama as well for some good hp gains and o2 sensors to be turned off
mazen123 is offline   Reply With Quote
long trip low quality gas Mustangman705 General Mustang Discussion 11 10-15-2013 09:08 AM
Acceleration stutter help. 9stan5 Pre-2005 V6 Mustang 4 07-24-2012 06:15 AM
Whats the Best MPG you have gotten on a long trip junoS197Bl08 2005-2010 V6 Mustang 30 07-30-2011 01:07 PM
2k RPM Stutter Influence 1996-2004 Mustang GT 5 03-03-2011 04:51 PM
Engine Stutter bobby02V6 Pre-2005 V6 Mustang 15 01-18-2011 10:48 AM
06:12 PM
