My rear end went out!! - Mustang Evolution
Old 01-02-2015, 04:36 AM   #1
Mobley's Avatar
So my rear end went out. Pretty sure its just the stock on the 2000 v6. I seen posts on people swapping out rear ends and since I gotta spend money might aswell make it better right. So what can I do? Do I just get a rear end out of a gt or what. Any info will help since its already at my family's shop
Sent from my SGH-M819N using Mustang Evolution mobile app
Mobley is offline   Reply With Quote
Old 01-02-2015, 02:52 PM   #2
EverettsV6Power's Avatar
Putting in a gt rear end will make it a 8.8 instead of a 7.5 as well as better brakes and limited slip diff that said you can go out and buy a brand new super rear end but the gt is around 350 plus cleaning and painting and the new rear end for a well built put together one is 1500 so it's all up to how deep your wallet goes
EverettsV6Power is offline   Reply With Quote
Old 01-02-2015, 09:41 PM   #3
A 28 spline 8.8" rearend from a 99-04 GT is your best bet. The rear brakes are the same so there's no gain there, however the rearend itself is larger and as Everett said you get the limited slip, or traction lok to be manufacturer specific.
This will get you better traction from a dig and eliminate those embarrassing one wheel burnouts
The v8 rearends also have quad shocks which can be transferred into your v6, the bolt holes are in the frame.
Unless you know the exact mileage of the car donating the rear and how it's been driven I'd plan on rebuilding the rear. Rebuild kits are available at vendors like American Muscle etc. You may also want to upgrade gears since you'll have the diff. cracked open. Keep in mind changing from the stock 3.27's and going to a taller ratio will throw your speedometer off slightly and will require calibration for it to be correct.
Finally, you can use a 94-98 8.8" rear but it will be ~.5" narrower on each side which would require hubcentric wheel spacers to push the wheels out so they don't look so tucked in.
Old 01-05-2015, 08:52 PM   #4
baddbradd's Avatar
I put a 98 gt rearend in my 01v6 for $150. I put 1.5" hubcentric spacers on each side, perfect. Rear wheel lip is flush with fender...
2001 coupe
baddbradd is offline   Reply With Quote
Old 01-31-2015, 05:53 AM   #5
Mobley's Avatar
Thanks guys I got a new rear end now, my family shop didnt even ask me they just went ahead and put another rear end on it and p.issed me off
Changing out rear end Milehigh STK General Mustang Discussion 104 04-13-2014 12:23 PM
Will the Rear end out of a 1988 cougar xr7 fit in a 97 mustang? meyer41 General Mustang Discussion 5 04-08-2010 02:13 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
OK the Calendar winners email went out Danger Dude The Bar 7 11-27-2003 05:04 PM
07:42 PM
