01 door speakers - Mustang Evolution
Old 01-07-2015, 09:17 PM   #1
AKE
AKE's Avatar
01 door speakers
My door speakers do not work but all my other speakers work. Does anyone else have this problem and does anyone know what it could be?
AKE is offline   Reply With Quote
Old 01-16-2015, 08:13 AM   #2
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
Both speakers blown, not wired properly,
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 01-16-2015, 08:25 AM   #3
fenixignition's Avatar
depends on whats going on. stock setup? stock head unit? if you wanna test if they work, then pull the door panel off, grab a AA battery, and connect the positive to positive, neg to neg, and you should hear some kinda of faint clicking buzzing or popping sound. means the connection is there. and that would lead to believe that the head unit isnt outputting the front channel. if no clicking or popping or buzzing, then the speakers blown. my stock 02 speakers werent blown but last year they were pretty worn out. if they are aftermarket, then it probably depends on the brand and their use to determine how long they last.
2002 GT 5sp. 16x,xxx miles
Old 01-16-2015, 10:29 PM   #4
AKE
AKE's Avatar
It might be my head unit then. I'll check it out. I know they weren't blown cause I tried to hook up new ones and they weren't getting power. Thank you
Old 01-19-2015, 12:40 PM   #5
Iryan7's Avatar
If you have Mach 460 sound system you could have a bad amp
Iryan7 is offline   Reply With Quote
Old 01-19-2015, 01:34 PM   #6
Totally forgot about that. That could very well be it. If it is a mach stereo then you gotta replace everything with aftermarket or use only mach460 parts. The resistance (ohms) isnt standard on the mach system
Old 01-19-2015, 02:32 PM   #7
Iryan7's Avatar
Or bypass the amp and run new speakers
Old 01-19-2015, 03:27 PM   #8
Isnt the stock head unit atill difficult? Idk ive never worked.with the machs.
Sent from my LG-D800 using Mustang Evolution mobile app
Old 01-19-2015, 07:00 PM   #9
AKE
AKE's Avatar
Well that sucks guess I'll be buying new amps 😬 thanks
Old 01-30-2015, 12:37 AM   #10
Iryan7's Avatar
01 door speakers
You can find the Mach 460 ones on eBay or at junk yards cheap. Personally I would run new amps and speakers, or even just speakers. I personally don't think you need Amps unless you're trying to make everything louder. If you want bass, put a subwoofer in. Door speakers, even kicker, will never compete with a real subwoofer
removing mach460 amps/speakers, running new amp to door speakers with stock wiring? paradigm 1996-2004 Mustang GT 0 07-31-2013 04:04 AM
Swapping 2013 door speakers claudermilk Mustang Audio & Video 1 07-31-2012 05:54 PM
Upgrading door speakers trumpet173 Mustang Audio & Video 6 05-22-2012 01:27 AM
08 mustang door speakers Mustangguy0202 Mustang Audio & Video 4 02-17-2012 08:03 PM
door speakers not working greenpony02 Mustang Audio & Video 1 05-26-2007 11:48 AM
06:28 PM
