Throttle cable adjustment - Mustang Evolution
Old 01-08-2015, 03:39 PM   #1
Dogbitdude's Avatar
Hey does anyone know how to adjust the throttle cable in a 2001 v6 vert? My pedal is resting at around 85% throttle but the engine is peaking at 15%ish
Dogbitdude is offline   Reply With Quote
Old 01-08-2015, 08:37 PM   #2
phatmike's Avatar
Region: Nebraska
I just put zip ties on my 97's cable and they've held up very well
phatmike is offline   Reply With Quote
Old 01-08-2015, 11:33 PM   #3
richie895's Avatar
You can use zip ties for a temporary fix or you can get clear spacers from like Home Depot. You basically just lift up the pedal and get rid of most of the slack, then put the spacers or zip ties to hold it in place
richie895 is offline   Reply With Quote
Old 01-09-2015, 10:51 AM   #4
mazen123's Avatar
Zip ties, like 4 or 5 should do it
mazen123 is offline   Reply With Quote
Old 01-09-2015, 10:56 AM   #5
fenixignition's Avatar
i have a gt, so i dont know how different it is on the inside, but what i did was take a little piece of rubber hose and some zip ties. i estimated a length of the rubber hose and sliced it along the side so i could put it around the throttle cable above the pedal, with a little metal ball piece resting at the top of it. then i put the zip ties around the rubber hose to hold it in place. therefore, the rubber hose worked as a piece of tubing that holds the slack up away from the pedal, and the pedal is raised up, and you can now get WOT about where it hits the floor.
hope that made sense....
2002 GT 5sp. 16x,xxx miles
Old 01-24-2015, 03:54 PM   #6
Jaytraeg's Avatar
+1 to everyone on this response. Zip ties, spacers of any sort, pretty much anything to keep that pedal up. I did it as soon as I got the car, and it made the car feel so much better.
Jaytraeg is offline   Reply With Quote
Clutch Cable adjustment? antnvlz1294 1979-1995 Mustang GT 30 03-27-2014 08:03 AM
clutch cable adjustment jacob.a.gasparp 1979-1995 Mustang GT 5 08-16-2012 02:57 PM
RAM clutch cable adjustment on 99 cobra nasty99 1996-2004 Mustang GT 2 06-01-2011 01:56 PM
Throttle Cable adjustment Renegade 800 Pre-2005 V6 Mustang 22 05-12-2009 06:56 PM
throttle adjustment question V6Stang33 Pre-2005 V6 Mustang 17 03-07-2005 03:15 AM
09:05 PM
