Gears or tune - Mustang Evolution
Old 01-10-2015, 03:48 AM   #1
xrsfx's Avatar
Gears or tune
I don't know wether to get 4.10 gears or tune my car. Which to do first..
xrsfx is offline   Reply With Quote
Old 01-10-2015, 05:16 AM   #2
cozny's Avatar
Tune, you will need to be able to recalibrate your speedometer. If your planning on eventually doing both get the tune first, because if you get the gears first you would have to get a calibrator for your speedometer.
cozny is offline   Reply With Quote
Old 01-10-2015, 07:34 PM   #3
You can get gears first but plan on either getting a custom/dyno tune or a custom tune via handheld tuner soon after to properly calibrate your speedo.
When you do "gears" also plan on getting a tlok installed as this will distribute power to both wheels for improved launches and better traction. Expect to pay $300-500 for a solid install. Stick to Ford Racing gears as they been known to mesh the best over Motives.
Old 01-10-2015, 07:48 PM   #4
If you get the gears first you won't have a way to adjust your speedometer. Get the tune first.
Old 01-17-2015, 09:41 AM   #5
Automatic OR Manual??
An automatic will have to be dyno tuned after gear install. Only buy Ford Racing gears and friction modifier.
Bama tune or lund tune or steeda tune Mustang32Bill 2011-2014 Mustang GT 89 11-12-2012 10:45 AM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
04:51 AM
