Brake issues - Mustang Evolution
Old 01-15-2015, 10:50 AM   #1
Brake issues
Yesterday I put new pads on the front and rear brakes and after installing the pads the pedal goes in very easily with little to no resistance, almost like the pedal feels like it's sticking, is this common after changing brakes pads or do I have a problem to address?
Thanks
Matthewgentle is offline   Reply With Quote
Old 01-15-2015, 07:57 PM   #2
Mile high JDF's Avatar
Did you build up pressure after installing the new pads? How did you compress the pistons?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-15-2015, 08:15 PM   #3
Did you open the brake valve at all? If you did it sounds like there is air in the system.
Old 01-15-2015, 08:39 PM   #4
BamaStang93's Avatar
Sounds like you need to bleed the brakes my friend.
BamaStang93 is offline   Reply With Quote
Old 01-16-2015, 08:08 AM   #5
I used a c-clamp to compress the pistons, I'm not sure if I built up pressure where would the pressure build up be?
Thanks
Old 01-16-2015, 08:15 AM   #6
Yes I think I opened the valve and because a bolt broke off in the caliper pin and I was scrambling to remove the pin and I didn't realize at the time that I had opened the valve. I'm planning to bleed the brakes tonight if that doesn't fix the problem then I'll let you guys know, thanks for all the help I really appreciate it.
On a side note, I apologize if I don't use all the technical terms for everything I'm 17 and just starting learning more on working with cars
Thanks
Old 01-16-2015, 05:54 PM   #7
Let us know how it goes!
I think we all understood what you were trying to say, it's good that you're wanting to learn.
Old 01-20-2015, 08:00 AM   #8
Sorry for the delayed reply I've been real busy over the weekend. Bleeding the brakes seems to have solved the problem thanks for all the help!
Brake Issues 1970fbm351 Classic Mustangs 3 10-20-2012 07:33 PM
Brake issues Medcyn 1996-2004 Mustang GT 8 05-25-2012 10:25 PM
Brake Issues cruiser4life Classic Mustangs 5 03-27-2012 08:57 PM
E-Brake cable issues captain78 1979-1995 Mustang GT 2 01-31-2012 10:19 PM
E-Brake Issues, please help Scorpion1 Pre-2005 V6 Mustang 11 11-22-2008 07:53 AM
05:13 PM
