Lifter tick! - Mustang Evolution
Old 01-21-2015, 06:27 PM   #1
2000v6_Nat's Avatar
Region: Nebraska
Lifter tick!
Alright so I've got 2 problems, lifter tick and rear main seal leak. The rear main seal came first and ticking came a couple months after. I'm getting the rear main seal replaced in the next couple weeks. With the lifter tick I find when I put in oil treatment and top it off (since I'm always leaking oil), it tends not to tick for awhile. Will the rear main seal replacement fix the ticking because the oil staying full?
No engine/performance mods (yet). Mach 460 sound system, 2 12" alpine subwoofers in a custom box w/ 1800watt kenwood amplifier. Smoked halo headlights, smoked sequential taillights, black bullitt staggered rims, racing stripes, and plastidipped spoiler. Future exterior mods - Chin spoiler, black fuel door, and demon fender flares (plastidipped).
2000v6_Nat is offline   Reply With Quote
Old 01-22-2015, 12:24 AM   #2
davidcseifert's Avatar
Region: Arkansas
If it goes away when you fill it up then yes I would believe it would stay away, but until you replace it keep a closer eye on your oil level and don't let it get low so they would tick more. You also need to consider why the rear main seal blew out, a common problem is a poorly functioning pcv system which causes excessive pressure and blows it out. They are cheap to replace (pcv valve).
blower/new cam soon
Old 01-22-2015, 07:11 AM   #3
2000v6_Nat's Avatar
Region: Nebraska
Okay, thanks! I'll keep posted after I get the rms replaced!
Old 02-09-2015, 10:29 AM   #4
How do you know the rear seals bad. I gotta go 97 V6 standard stang and after a while of driving I smell a mixture of burnt oil and brake pads. I looked under the car inside the clutch peek panel and it looks like there's oil in there, Idk if it's front the engine or trans?
Sent from my SCH-S738C using Mustang Evolution mobile app
---------- Post added at 05:29 PM ---------- Previous post was at 05:28 PM ----------
*Idk if it's from the engine or the trans
97Redstang is offline   Reply With Quote
Old 02-09-2015, 10:37 AM   #5
2000v6_Nat's Avatar
Region: Nebraska
Turns out I was wrong. Well not me, the shop I previously took it to. When I took it to the shop to have the rear main replaced they cleaned it up and said no way it's a rear main, they said it was valve cover. They told me the best way to identify rear main leaks is to clean up the entire area and see if oil drips form at the bell housing. They said they did this and the oil was coming from higher but appeared to me as rear main because it collected at my car's lowest point.
Lifter tick and scraping metal sound among other things Cmccully Pre-2005 V6 Mustang 0 01-08-2015 10:04 AM
TICK TICK TICK Mustangman705 1996-2004 Mustang GT 13 09-21-2013 06:30 AM
Ticking Lifter Cervantes107 1996-2004 Mustang GT 6 02-13-2012 03:53 PM
Lifter tick? NeedSomeMods 1979-1995 Mustang GT 3 12-18-2011 09:34 PM
Terminator Lifter Issues SaleenFiend 1996-2004 Mustang GT 11 10-28-2010 06:44 AM
12:27 AM
