Odometer cuts off - Mustang Evolution
Old 01-25-2015, 10:01 AM   #1
Jaytraeg's Avatar
Odometer cuts off
Hey guys, I've got a question. So, every now and then when I'm driving, the odometer will turn off and stop reading. It comes back on after a while of driving, and reads correctly, but it is still rather annoying. Anyone might know what this is?
Jaytraeg is offline   Reply With Quote
Old 01-25-2015, 03:50 PM   #2
My '02 does the same thing! What I'm thinking it is, is a cold solder...I've looked over other forums with others having the same issue. One person took their cluster apart and checked it out for cold solders and low and behold that's what their issue stemmed from. I just haven't made the time to pull mine apart and check... Hope this helps!
Sent from my Galaxy Nexus using Mustang Evolution mobile app
truedeath is offline   Reply With Quote
Old 01-30-2015, 12:28 AM   #3
Iryan7's Avatar
Same, but whenever I tap mine it fixes itself
Iryan7 is offline   Reply With Quote
Old 01-31-2015, 04:00 PM   #4
It could be a loose connection. I've had a very similar case happen with a 1997 Dodge Caravan. The connectors in those vans were garbage from the beginning and there's no REAL fix to it unfortunately for me. But I'm almost positive there are many aftermarket cluster connectors that will give a better connection for the mustang. Worst case scenario you may have to buy a whole new cluster and get it calibrated to the right mileage.
tsteevs_foxbody is offline   Reply With Quote
Old 03-31-2015, 12:57 AM   #5
sguilliams2006's Avatar
At least I am not the only one that has been having this issue. My 02 does this and it makes it difficult to clear my mileage accurately when I fill up my tank. I am afraid I have no clue what a cold sodder is so I wouldn't know what to look for in that case.
sguilliams2006 is offline   Reply With Quote
Odometer cuts in and out Iryan7 Pre-2005 V6 Mustang 5 07-25-2014 03:16 AM
Engine cuts off rathke83 1996-2004 Mustang GT 3 06-01-2014 12:32 AM
Engine cuts off for 2 seconds then is fine again?? alant007 2005-2010 Mustang GT 0 03-04-2013 07:19 PM
1990 mustang cuts off when put in gear to drive 2.3 engine automatic trans? gillecriosd 2.3 Mustang 0 12-18-2011 12:30 PM
Car cuts out in the morning. Black00GT The Bar 6 02-17-2004 09:33 PM
05:36 PM
