The Vanishing Coolant!! - Mustang Evolution
Old 01-26-2015, 08:34 AM   #1
TreyDeluxe's Avatar
98 3.8 130k. Short back story: Had a bad cracked radiator in november. changed radiator, ran good, not overheating until couple weeks ago. checked coolant levels and its empty!? i haven't noticed any fluid on the garage floor. filled up coolant and kept on going. last thursday the 22nd i filled up again and marked where my level was (see pic) the black line is where it was an now you can see how much fluid i've lost (pic taken on 25th) there is no visible leak inside or outside car. i can smell the coolant inside and out. i did a block test to see if i have a cracked head, head gasket etc (see pic) and i guess it passed. what could be my problem?? help!!
ID:	174271   Click image for larger version
TreyDeluxe is offline   Reply With Quote
Old 01-26-2015, 10:13 AM   #2
davidcseifert's Avatar
Region: Arkansas
If you can smell it there is most likely an external leak, but onto something hot so it burns away before dripping to the ground so you can't see it on the ground. Look around the motor for a damp spot after it gets warmed up to give it a chance to leak.
blower/new cam soon
Old 01-26-2015, 10:16 AM   #3
Region: Arkansas
Name:	ImageUploadedByMustang Evolution1422292453.090596.jpg
For example a cracked weld on an old head I had it had a strong coolant smell but all burned off before it dropped onto the ground.
blower/new cam soon
Well its winter time CHANGE your coolant SpectorV The Bar 11 11-22-2005 09:02 PM
Coolant question bryanscle Pre-2005 V6 Mustang 12 06-09-2005 09:02 AM
Change you coolant regularly SpectorV Pre-2005 V6 Mustang 4 11-22-2004 11:54 AM
Coolant Change 99v6TxStang Pre-2005 V6 Mustang 6 11-10-2004 06:10 PM
coolant leak josh97gt Pre-2005 V6 Mustang 7 09-01-2004 10:38 AM
06:06 AM
