Needing input for top end work! - Mustang Evolution
Old 02-06-2015, 06:33 PM   #1
2000v6_Nat's Avatar
Region: Nebraska
Okay, okay! I have a lifter tick AND a leak in my valve cover gasket. I had thought for a long time that is was a rear main (untrustworthy shop told me so) but a shop run by my friends dad set me straight today. Phew! That means $500 saved... Because I have no lift or tranny jack, that was why I was going to have shop do rear main...
Anyways! I do have the means to do top end work. Which means I plan on pulling the intakes and covers (not the heads since the head gasket was done 10k miles ago) I plan on replacing lower and upper intake gaskets and the leaking valve cover gasket. I also plan on pin pointing the lifter that's ticking while praying it didn't damage the cam at all and replace it. My question is should I do all the lifters and pushrods while I'm in there and what else? I'm not really caring about performance cause it's just my daily driver so if the cam is fine I'm keeping it don't need a supersix lumpy cam or whatever lol.
Also question regarding 8.8 rear end. I would definitely like one for both tires spinning, but should I get a stock one with low miles or get one and rebuild it with 4.10. Like I said earlier performance isn't a huge deal, I just think the 8.8 would give me better traction in this nebraska winter.
Thank all for your time!!
No engine/performance mods (yet). Mach 460 sound system, 2 12" alpine subwoofers in a custom box w/ 1800watt kenwood amplifier. Smoked halo headlights, smoked sequential taillights, black bullitt staggered rims, racing stripes, and plastidipped spoiler. Future exterior mods - Chin spoiler, black fuel door, and demon fender flares (plastidipped).
2000v6_Nat is offline   Reply With Quote
Old 02-06-2015, 09:33 PM   #2
2000v6_Nat's Avatar
Region: Nebraska
Also an extra tidbit, I know in couple engines you're actually capable of taking out the lifter through the hole the pushrod goes through. Does anyone know whether it's possible on the 3.8l?
Old 02-07-2015, 03:36 PM   #3
2000v6_Nat's Avatar
Region: Nebraska
Also, on the gaskets should I use a type of sealant or glue to?
Old 02-13-2015, 11:19 AM   #4
2000v6_Nat's Avatar
Region: Nebraska
Buuuuuuump
Old 02-14-2015, 12:37 AM   #5
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
Using a light bit of RTV on the valve cover gaskets is always a good idea and will help to keep them in place as u put things back together! For ur lifter all u should need to do is some adjustment unless the lifter has collapsed? If u replace one though u should replace them all!!! They usually come in a kit anyway.
Jmustang78 is offline   Reply With Quote
Old 02-14-2015, 12:40 AM   #6
Jmustang78's Avatar
Region: Montana
Btw the 8.8 is only gana give u a limited slip if u start spinning u start spinning but with 2 tires instead of 1 lol if it's ur daily driver I would not go with a 4:10 gear.
08 gt front end issues (need input) codys08gt 2005-2010 Mustang GT 1 11-12-2014 03:41 AM
08 gt front end issues. (Neeed input) codys08gt 2005-2010 V6 Mustang 0 11-12-2014 02:13 AM
Doing some work, maybe more... need input. Checkmate Pre-2005 V6 Mustang 1 09-01-2006 11:55 PM
Stang needing to be put down PureVenom The Bar 19 03-19-2005 11:22 AM
Moving to Cincinnati Ohio, Needing some info!! kaper232 The Bar 8 11-06-2004 11:28 PM
05:19 PM
