Cranks But Won't Start - Mustang Evolution
Old 02-25-2015, 12:07 PM   #1
I have a 2000 Ford Mustang 3.8 that cranks but won't start. ( YOUTUBE LINK TO A VIDEO OF MY PROBLEM )
I got the car and it worked perfectly the entire day ( must of started it about 10 times )!
The next day it would not start sometimes it sputters/coughs .
I changed the spark plugs and wires. My battery is brand new.
After i started i attempted to start it many, many times, i pulled a plug and its black and has fuel on it
I also checked all the fuses ( under the dash and the hood)
I contacted the old owner and he said he never had any problems.
I get no codes coming off of it.
I have a good fuel pump because i hear it prime when i turn the car on, and gas spits out the schrader valve when i tested it….
Also, if i spray starter fluid in the throttle body the car won't start ( not even for a couple seconds )
I also forgot to mention that i did manage to get it started a couple days ago, and realized that BOTH catalytic converters where blocked THEY WHERE RED HOT, i took the exhaust system off and it started and would only stay running if i had my foot all the way down on the gas, if i tried to shift into drive it would almost die and would not move an inch. I put the exhaust back on and now it will just cough, it won't stay running. Please help me out!
Any help would be greatly appreciated!!
Danny411 is offline   Reply With Quote
Old 03-01-2015, 01:34 AM   #2
Region: Utah
I kind of have the same problem as you but not exactly. Recently i replaced my clutch so that means i had to take starter off and the flywheel. When i reinstalled everything it was harder to start sometimes. It sounded just like your car and i thought i broke my starter. Well after getting some info i learned that the teeth from my starter sometimes got out of line with my flywheel so it wouldnt turn. All i had to do was roll my car forward a bit for it to start. Soo it could either be that but its a very low chance or it can be your starter all together. Hopefully that helps a little bit but i know its not much
kb3030 is offline   Reply With Quote
Old 03-03-2015, 05:13 PM   #3
Bravebowhunter's Avatar
Have you replaced the coil pack?
Bravebowhunter is offline   Reply With Quote
Old 03-03-2015, 06:45 PM   #4
fwalck's Avatar
It could also be a crank sensor check to see if you have injectors pulses if you dnt my bet would be on that because it controls the spark and injectors
fwalck is online now   Reply With Quote
Old 03-03-2015, 06:55 PM   #5
Cam sensor controls the spark if it's not the coil pack I would do that next.
Old 03-04-2015, 11:53 PM   #6
PiojoA7x's Avatar
Had a similar problem. But mine started when I sprayed starting fluid. Don't know what the cause of mine was. All though it did rain hard the night before. Maybe water got inside my charging system or something got affected by the rain
PiojoA7x is offline   Reply With Quote
Cranks But Won't Start Danny411 Pre-2005 V6 Mustang 0 02-25-2015 11:50 AM
Car cranks and cranks then starts weak Anth0nyxGT00 1996-2004 Mustang GT 6 02-21-2015 02:50 PM
2000 V-6 Cranks but won't fire jbow Pre-2005 V6 Mustang 2 12-25-2014 09:21 AM
89 GT cranks every time but won't start MOST TIMES! HELP!! Red89 1979-1995 Mustang GT 43 01-28-2014 04:35 PM
1995 GT cranks but no start hot 89beretta 1979-1995 Mustang GT 9 07-26-2009 08:23 PM
08:07 AM
