ABS light - Mustang Evolution
Old 03-11-2015, 04:33 PM   #1
ABS light
Is the ABS light staying on after a brake job and brake bleed a common issue with Mustangs?
rosad is offline   Reply With Quote
Old 03-11-2015, 05:02 PM   #2
Blakhwk's Avatar
No it's not common, check the ABS sensors and wires for lose and dirt.
Visca Barça
Blakhwk is offline   Reply With Quote
Old 03-11-2015, 05:21 PM   #3
Speed sensors. Plug in an obd scanner and it will tell you. Mine says its the right rear speed sensor
Old 03-14-2015, 06:13 AM   #4
TwoWhiteGirls's Avatar
It's common for sensor wires to get damaged do to rough handling at shops. Just pull the wheel and take a good look around chances are you'll find your damage. If it's a broken wire it's too easy to fix.
TwoWhiteGirls is offline   Reply With Quote
Abs rear to non abs rear? misterpancho95 Pre-2005 V6 Mustang 0 01-21-2015 09:29 AM
abs on non abs sledgehammer General Mustang Discussion 4 01-28-2010 11:30 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 02:21 PM
ABS light Zim 1979-1995 Mustang GT 9 10-13-2006 06:25 PM
ABS and Traction control light on rugman1969 1996-2004 Mustang GT 1 09-30-2006 03:09 PM
03:39 PM
