Odometer - Mustang Evolution
Old 03-13-2015, 04:05 PM   #1
Odometer
Ok so my odometer stopped working, and in 94 _98 mustang the gears strip around 130000 . So I replaced it no problem. It worked for about 3 miles then stopped. Any idea why?
Sent from my Z970 using Mustang Evolution mobile app
grim25 is offline   Reply With Quote
Old 03-14-2015, 10:36 AM   #2
phatmike's Avatar
Region: Nebraska
Did you make sure to snap the driven gear into place? I don't see how something would've actually snapped after 3 miles..
phatmike is offline   Reply With Quote
Old 03-14-2015, 11:07 AM   #3
I thought I did I felt it pop in. Could the motor have burned up
Old 03-14-2015, 11:47 AM   #4
phatmike's Avatar
Region: Nebraska
What I would do is take out the whole assembly again and check for any broken pieces on the driven gear and make sure you left about a thumb nails width between the worm gear and the motor and also make sure you removed all of the old broken pieces from your old gears. You might as well check the motor while you're in there too
Old 03-14-2015, 01:08 PM   #5
Maybe it's the worm gear ,cause I didn't leave space between
---------- Post added at 07:08 PM ---------- Previous post was at 07:08 PM ----------
Thanks phatmike
Old 03-16-2015, 01:57 PM   #6
Well wasn't the worm gear made sure there was space cogs were pushed all the way in. Still not working
Old 03-16-2015, 02:34 PM   #7
phatmike's Avatar
Region: Nebraska
Then the only thing I can think of is a bad motor/bad wiring
What does your Odometer read? DarkShadow General Car Discussion 54 06-18-2007 09:53 PM
Speedo/Odometer Gears floridamba Pre-2005 V6 Mustang 5 05-01-2007 08:32 AM
Speedo works, Odometer does not.. floridamba Pre-2005 V6 Mustang 9 04-24-2007 03:02 AM
Odometer Stopped Turning Brent Pre-2005 V6 Mustang 7 09-14-2006 09:24 AM
post pics of your odometer cluster maximus Mustang Audio & Video 16 08-02-2006 09:34 PM
04:13 AM
