Low idle 24/7 - Mustang Evolution
Old 03-18-2015, 02:25 AM   #1
Iryan7's Avatar
Low idle 24/7
My car idols at around 550 whenever I'm stopped at a red light or start it warm. The only time my car idles differently is when I start it cold, then the idol starts high (over 1k) and lowers slowly. Any ideas why my car is doing this? Is there something I need to adjust? Thanks in advance. 2001 3.8 auto 181,500 miles
Iryan7 is offline   Reply With Quote
Old 03-18-2015, 09:42 AM   #2
cozny's Avatar
That's normal.
cozny is offline   Reply With Quote
Old 03-18-2015, 10:20 AM   #3
Iryan7's Avatar
Low idle 24/7
I've never had a car idle at almost 500 on a daily basis. It use to idle at 750
Old 03-18-2015, 10:31 AM   #4
cozny's Avatar
Have you changed oil weight? And at start up it should go up past a little bit over 1k then after give or take 30 seconds it should down around 600-800 wich a safe range and 550 not far off so I really wouldn't worry about it.
Old 03-18-2015, 10:48 AM   #5
Iryan7's Avatar
I started using high mileage oil but even before that it did the same thing. It just feels weird seeing my tac at almost 500 every time I stop
Old 03-20-2015, 02:34 PM   #6
Iryan7's Avatar
After changing my idle pulley it idles normally again so far. It was pretty worn out.
Old 03-20-2015, 02:54 PM   #7
2 Stangz's Avatar
Region: Nevada
High idle @ cold start is intended. Car runs in open loop fuel mode (i.e. running rich) before reaching operating temperature, so pulls in more air momentarily.
You can always do the idle relearn strategy (what I do after loading a new custom tune or between cold and hot seasons). I personally use my SCT to reset my KAM memory but if you don't have one you can do the following to obtain optimal idle quality:
Disconnect battery > let sit for a while > reconnect >start car w/o AC on, let it idle until it reaches operating temp (watch the gauge on the dash) usually takes 5-10 min > let it idle for 1 minute at operating temp > turn on AC, let idle for 1 min > done, now do normal driving to relearn the rest.
Old 03-20-2015, 03:09 PM   #8
Iryan7's Avatar
I didn't know you could do this, thanks. Will keep this in mind.
How low is too low? McQueen 2011-2014 Mustang GT 47 01-19-2013 10:37 PM
Looking for a set of low low ratio 7.5" gears PureVenom Pre-2005 V6 Mustang 4 08-13-2008 04:15 PM
03 Gt Pi Heads And Cams!!!! Low Miles/low Price alwaysthefinest Mustang Parts for Sale and Wanted 1 05-24-2007 05:17 PM
how low is too low? Kyle Mustang Audio & Video 41 01-25-2007 08:53 PM
CAI installed... low idle problems... RedStang830 Pre-2005 V6 Mustang 16 08-03-2003 08:33 PM
12:13 PM
