NEED HELP ASAP - Mustang Evolution
Old 03-21-2015, 12:25 PM   #1
NEED HELP ASAP
I have a v6 auto basic mustang. I started it this morning and was making a weird sound. When I put it in reverse it grinded, and again into park then it died . Now it won't start. The lights all come on and radio. But when I turn the key nothing not even clicking. Any ideas? I know it's not the battery or relay.
Sent from my Z970 using Mustang Evolution mobile app
grim25 is offline   Reply With Quote
Old 03-21-2015, 01:39 PM   #2
Region: Delaware
Sounds like at least the starter motor is dead
1st mustang, first car- bought mid November 2014- 2004 v6 convertible w/ 85k miles, v8 exhaust, fast enough to get in trouble...
Marcus0716 is offline   Reply With Quote
Old 03-21-2015, 01:50 PM   #3
It's there an easy way to test it?
Old 03-21-2015, 02:26 PM   #4
Tyoung68's Avatar
When you try to start it does it make any noise?
Old 03-21-2015, 03:09 PM   #5
None not even clicking
Old 03-21-2015, 03:14 PM   #6
Tyoung68's Avatar
What do your batter terminals look like? Sounds like you lost a ground i had a similar situation happen
Old 03-21-2015, 03:16 PM   #7
Good not corroded or anything. I even took them off and hooked them back up
Old 03-21-2015, 03:21 PM   #8
Tyoung68's Avatar
Did you try to clean them? I guess next step would be to see if you got power to the starter. Not sure how/where to probe but all you need is a test light and find which stud on the starter is the power one and hook up the alligator clip from the test light to it and then touch the end to ground and have someone turn the key and see if it lights up
Old 03-21-2015, 03:27 PM   #9
blowa's Avatar
when you put cables on ,...have someone try n start it and you move the terminal ends in different positions to try to get a good connection.
2014 V6, Oxford White, Auto, 3.31, AirRaid CAI, MBRP axleback, 18" Motegi Black MR118, Cooper RS3-S's, MPT 93/Perf/Race[Ghost Cam], Steeda Ultra springs, B&R Panhard Bar, Ford Racing strut brace, BMR LCAs, JLT Oil Separator, Kicker 12'' Sealed Sub/300wt. amp, Formula1 70% tint[+windshield]
blowa is offline   Reply With Quote
Old 03-21-2015, 03:47 PM   #10
Terminals and connection is good . Is there an easy way to get the starter off?
Old 03-21-2015, 08:01 PM   #11
Under the hood there is a fuse box with "ignition relay" listed for a few fuses. Check them.
Ground wires need checked, cleaned.
Old 03-21-2015, 08:16 PM   #12
I already checked all that.
Need Sub Box Help ASAP! FloMasta24 Mustang Audio & Video 22 04-03-2005 11:14 PM
need help asap!!! Monkey Pre-2005 V6 Mustang 17 06-20-2004 11:24 PM
*UPDATED W/PICS* Need help ASAP! 01mineralgrey6 Pre-2005 V6 Mustang 28 03-15-2004 08:41 AM
Need Help with Viruses on my COMPUTER! HELP ASAP!! Autobadges.com The Bar 41 02-05-2004 09:53 PM
Car overheated!!! NEED RADIATOR ASAP HELP!!!! Autobadges.com The Bar 18 11-15-2003 12:36 PM
11:02 AM
